How many guys would be intrested in one of these?
Old Oct 11, 2005 | 08:01 PM
  #76
G352NV's Avatar
Never enough
Heres the thing. Its a LOT of work to do these. The only way I can get the price to where it is will be to make one and make a mould. That cuts my time down to about five hours or so for each one. I can do custom ones but the labor rate is going to be higher. The one part your looking at is not even close to done. I just wanted to post it so you guys can get a idea. That part in the end will have about 10 hours in it. No BS!
Old Oct 11, 2005 | 09:41 PM
  #77
lowrider's Avatar
Have you thought of an exchange basis for that console piece, like Crawford used to do? It really is beginning to look good.
Lou
Old Oct 11, 2005 | 09:46 PM
  #78
G352NV's Avatar
Never enough
Well I wanted so the owner could switch back at anytime. Thats why Im trying to include it.
Old Oct 11, 2005 | 11:32 PM
  #79
accordfreak's Avatar
what kind of materials did you use to make it the way it is? fiberglass?
Old Oct 11, 2005 | 11:35 PM
  #80
G352NV's Avatar
Never enough
Yes
Old Oct 12, 2005 | 01:37 AM
  #81
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
CRAP! Well, without EDFC, I'm out. That's where my EDFC is now, so I would have needed that. How how much if you need a two 52mm with edfc and gauges, like you showed in the original post?
Old Oct 12, 2005 | 01:47 AM
  #82
G352NV's Avatar
Never enough
Well I would have to build a cage for it. Or find a way to make it stay in. Thats why I really didnt want to do it. I also dont know if you would have to cut out behind the console so it would fit. As for price Im guessing a three pod or EDFC would make it about 100.00 more.
Old Oct 12, 2005 | 02:01 AM
  #83
G352NV's Avatar
Never enough
Ok guys I should have this one and another one in primer tomorrow. Who on the first page wants this one and with what two gauges? As for the other one it can be a three pod but will have no hazard. It will be 150.00 more WITH a 3rd gauge. Or it can be another two gauge console. After this I dunno when Im going to get more consoles in. I have nine on order right now but they are back ordered.
Old Oct 12, 2005 | 02:27 AM
  #84
a.k.a. RANDYS_G
how did you do the one in the first pic you showed...where EDFC was there?
Old Oct 12, 2005 | 02:37 AM
  #85
RashMan1450's Avatar
Randy there was no EDFC. man i think there are like somewhere on about 5 or more members that want this console with the edfc put in. Only if this could be done.
Old Oct 12, 2005 | 03:28 AM
  #86
G352NV's Avatar
Never enough
Like I said it can be done, its just going to cost more. You guys know me, anything can be done.
Old Oct 12, 2005 | 08:17 AM
  #87
Brando's Avatar
I Want it!!!!!
I need a boost and fuel pressure guage......
Old Oct 12, 2005 | 08:20 AM
  #88
lowrider's Avatar
I would like one - Gauges I want are simple, Voltmeter and Oil Pressure.
Lou
Old Oct 12, 2005 | 09:10 AM
  #89
KraftBMW's Avatar
I want a 2 gauge with hazard. Check PM. Thanks.
Old Oct 12, 2005 | 10:34 AM
  #90
lowrider's Avatar
Just a thought here. Are you aware that there were two console pieces available in 2003. The early Coupe had one with no ash tray, ir had a cubby. That was the one used before the console change, when the Coupe used the "Z" console. I don't know that part number, but it should work for this application. Both are interchangeable with the later console. I'm one of the one's who retrofited the later console, and I'm still using the piece with the cubby. The early one may be easier to get. Just a thought.
Lou
