Greddy TT question
Old Oct 15, 2005 | 11:28 PM
SiLvErG3585's Avatar
Greddy TT question
I am very interested in having a Greddy TT installed on my 04 5AT coupe but I was wondering how reliable would this be? Would I be able to use it as an everday driver, and on stock internals? And how long would my engine last in the long run, I currently have an HKS hi-power exhaust but that is the only engine mod. I have. Your opinions would be greatly appreciated. thanks
Old Oct 29, 2005 | 12:02 PM
NEXSTAGE350's Avatar
u will need some additional items along with the kit to run on stock.. with good tuning u should be fine.
Old Oct 29, 2005 | 09:08 PM
Iceman8's Avatar
--spend extra money for a better kit! Install, reliability,finish,performance and gas miliage all suck.
Otherwise go supercharger.
Old Nov 2, 2005 | 06:41 PM
Would the APS be a better choice or would yall still recomend replacing the internals if I were to put any turbo kit on. replacing the internals is what I was trying to avoid having to do all at once. I really wanted to go FI but i wanted to go TT but, I might just have to settle for a supercharger.
Old Nov 2, 2005 | 07:24 PM
GXCLUSIV's Avatar
You can go either APS TT or Greddy. With Greddy kit you will need a return fuel system, shielded CAS wire, Walbro 255, timing harness and a very good tune, to keep it running safely. Best to stay with stock boost and at 400rwhp or less. With APS kit, its possibly the most complete kit out of box. No tuning needed, if your G is completely stock. Once you add mods that make it run lean, you'd better have a qualified unichip tuner in your area. Vortech or Stillen SC would also be a good choice.
Old Nov 2, 2005 | 08:43 PM
thanks for the informative response GXCLUSIV, that helped me alot with what I was trying to get to. Sounds like the APS would be a good choice but is the HKS Hi-Power exhaust going to be a problem with my car running lean or would I be alright, I dont have any mods except that cat-back sys.
thanks
Old Nov 2, 2005 | 09:32 PM
GXCLUSIV's Avatar
Your HKS high power is only 2.25" piping and will be just fine, however if you go with either a 2.5" or 3" exhaust then it may run lean or if you decide to add an aftermarket plenum. I know you prefer Twins, but you should also consider Turbonetics ST or APS ST, but your HKS exhaust will need to be modified with a " reverse y-pipe ". Also consider, install for the Twins will range from $2000-3500 depending on shop hr.rate. Install for the ST or SC will be around $750-1500. APS TT is around $7500, APS ST around $5500 I think. Vortech and Turbonetics is pretty close somewhere around $4200. Greddy with Intercooler and ALL parts needed to make it safe, might cost more than an APS TT.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
yosip1115
Forced Induction
Jan 28, 2016 02:51 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
