G35 & G37, Coupes & Sedans
Very odd problem. All climate control lights/AC on! Help!
Old Jun 4, 2006 | 02:21 AM
Jeff92se's Avatar
Red Card Crew
drivng home tonight. Suddenly ALL the climate control lights go ON(by itself). Fresh air and recirc lights are on at the same time. AC goes on full blast at 60 deg. Pushing all buttons do nothing. Temp up/down does nothing to change the temp setting. OFF button does nothing. Turning car off/on still results in the same thing. Radio was on. Turning it off works. But it won't go back on.
I checked the battery voltage when off 12.0x volts. When the car is started w/ all the AC/blower stuff on = 14.0x volts. So I "think" the battery is okay.
Anyone know what this is? Tough to drive around w/ the AC blasting all the time!
Old Jun 4, 2006 | 10:30 AM
Msedanman's Avatar
O.F. Administrator
My guess is that the Body Control Module has crapped.
Have the dealer check it -- (warranty)...
C.
Old Jun 5, 2006 | 11:34 AM
Jeff92se's Avatar
Red Card Crew
Odd. I hooked up my OBDII tool and while I was waiting for it to load up, I popped the hood and fiddled with the fuses. I jiggled the BCM fuse block. I went back into the car and it suddenly was working normally. I drove into work today and it was okay. But I think I'll have the dealer look at it anyway.
My scanner indicated a P1815 code but no CEL light.
Old Jun 7, 2006 | 12:11 PM
gagt2's Avatar
Code:
http://travelinvan.com/images/common/vansmall_300x185.gif
Old Jun 7, 2006 | 04:52 PM
Jeff92se's Avatar
Red Card Crew
What in the holy idiot posts is this supposed to be??
Originally Posted by gagt2
Code:
Freeman186
Sep 6, 2023 10:07 AM
NailBomb
Oct 28, 2015 07:53 AM
AesonVirus
17 Inch
Sep 20, 2015 02:05 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
