Hey all.
I have 05 G coupe AT about 1 year and 4 months old since I bought it and i have about 6500 miles on it.
I checked my coolant level is I realized that it's almost GONE!
I searched couple threads about the coolant problems and some people said that I need to find the reason why the coolant level got extremely low.
Do you guys think that I should take it to dealer for further investigation as to why it got extremely low or should I just put some more coolant in and see if it drops extremely fast again before I take it to dealer?
It's pretty hard to believe that it happened considering the miles and how long I've owned this car is low, etc. Don't you do coolant replacement/refill around 30k or 2 years+ ?
Thanks.
Thanks.
Fill it to the 'MIN' line again, with the engine cold. Then start keeping a close watch on it. If the drop is noticeable after several weeks I would take it in and have it checked out.
I would not go past 36K or 3 years with the same coolant. About the same interval I would use for a brake fluid flush.
