G35 & G37, Coupes & Sedans
Homelink (Rearview mirror) failure
Old Nov 26, 2006 | 05:04 PM
lelg35's Avatar
Recently, my homelink (rearview mirror) started failing. It's working sporadically (and as time goes on, it's working even less frequently).
If you notice, the green light by the buttons stays green until you press on one of the programmed buttons. If programmed, the green light flashes red. If it's not programmed, it just glows red (instead of green) and doesn't flash.
My failure is that when I press on the programmed button, it stays green. Even when I press the non-programmed buttons, it stays green. Now, I know it's still programmed because when it decides to work, it opens my garage door and the light flashes as I described above.
Anyone have any similar problems? Fixes? I'd like to see if others are having similar problems. I get nervous thhinking about having the dealer techs go in my car and take things apart. They're so careless.
Old Nov 26, 2006 | 09:04 PM
GreenGoblin's Avatar
The goblin resurrection
it might be defective if the car is still under warrenty I would let them replace it
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
the93owner
Sep 28, 2015 10:37 PM
the93owner
Sep 27, 2015 05:23 PM
TNRocker
Sep 21, 2015 08:36 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
