G35 & G37, Coupes & Sedans
Another set of Sentra-R Brembo calipers billed as G35/350Z ones, so be careful
Old Dec 9, 2006 | 03:16 PM
johnadlertech's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...m=190058879772
Old Dec 9, 2006 | 03:28 PM
Nismo G's Avatar
Thanks for the heads up!
How do you know they are for the sentra though??
Old Dec 9, 2006 | 03:45 PM
Someone with a sharp eye picked out a set on the forum a few months ago. I did not even know you could get Brembos on a Sentra (not anymore for 07, but maybe 06). On the front of the face below the Brembo logo their should be a cast in divit/circle. Just look at some forum pictures. They are close but not the same. The Sentra ones are probabally rarer, but who wants a Sentra?
Old Dec 9, 2006 | 03:47 PM
Nismo G's Avatar
I dont think i would want a sentra (considering i baught a G), but if the sentra brakes are the basicly the same why not buy them?? Fronts are 4 piston on the G and the rear are 2 piston (for the brembo models). He says that the front ones for sale are 4 piston....must just have different mounting points...
Old Dec 9, 2006 | 04:03 PM
bull3t's Avatar
also the g35/350z calipers have a line indentation under the brembo logo that goes from one end to the other...
Old Dec 9, 2006 | 04:25 PM
They use smaller rotors then the G/Z Brembo set up.
Old Dec 11, 2006 | 12:07 PM
EverythingG35's Avatar
The sentra Calipers are designed for a skinnier rotor as well.
Sentra Brembo brakes run a rotor that's 22mm thick and the G35/350Z setup runs a thicker 30mm rotor. Also, the Sentras only got the Brembo option up front, where as the G35/350Z's got them on all four corners.
Edit: That price on ebay is WAY expensive for Sentra Brembo calipers too. I upgraded to the Brembo calipers, rotors, pads, etc... on an Infiniti G20 for less than that, buying all the parts new through Nissan Motor Co. (we do more than just G35 stuff here at the shop). They're sorta able to use the same pads too... they're the same design, just a different thickness.
______________
Justin
Old Dec 11, 2006 | 02:52 PM
gqraverice's Avatar
they look hella small in the picture.
Old Dec 11, 2006 | 03:34 PM
The pictures are deceiving... they're huge calipers.
Frankieg35
Mar 20, 2016 09:42 PM
MikeTanabe
Brakes
Aug 26, 2015 03:02 PM
mushu
Jul 15, 2015 03:55 PM
