G35 & G37, Coupes & Sedans
Speedo Correction help
Old Jan 10, 2007 | 07:31 PM
GR8TG35's Avatar
If your 19 setup is the same aspect ratio as your stock 17's, you shouldn't have any problem....as long as the diameter of the tires don't change you will be fine....
Look in the wheels/tires section, they will have a wheel/rim calculator that will give you an idea of what effects changing tire sizes will have on your car/speedometer.
A rule of thumb is to keep the diameters within a 3% margin, this will ensure you will have no problems with your VDC/ABS sensors Kicking in all the time...
hope this helps.....
Old Feb 23, 2007 | 07:46 PM
vansterdam's Avatar
Your speedometer will only be about 1.5% too slow which is not a problem.
Here's a tire calculator link to compare tire sizes.
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
twentyeggs
Sep 11, 2015 03:58 PM
