G35 & G37, Coupes & Sedans
Dyno Test
Old Feb 23, 2007 | 01:51 PM
D's06G's Avatar
Dyno Test
I dynoed my car the other day and i pushed out 265whp and 259tq on a fourth gear pull and i have a few things pulleys, nismo cai, mrev, spacer, injen exhaust. Are those results right with the mods that i have?
Old Feb 23, 2007 | 01:53 PM
sloppymax's Avatar
what kind of dyno was it and did they give a disk with the runs on it?
Old Feb 23, 2007 | 01:55 PM
D's06G's Avatar
it was dyno jet, i never got a disk just the paper w/ the results
Old Feb 23, 2007 | 02:00 PM
ResIpsa's Avatar
How dare you post numbers like that on this message board. With those mods? Either your flat out lying or the dyno operator was on crack!
I'm already on to you, don't even try to pass a counterfeit photo shop (do they even make that program any more?) dyno graph. I'm not buying what you are selling.
Old Feb 23, 2007 | 02:05 PM
DieselX's Avatar
Is your car tuned or it's just with the bolt-ons you listed? Numbers are a little too high for those mods. Not as bad as the Mustang Dyno I did hahaha... 298 hp!
Old Feb 24, 2007 | 06:33 PM
OCG35's Avatar
The answer to: "Are those results right with the mods that i have?" is simply: No.
way too high... without posting your dyno sheet most are going to think you are BSing.
Old Feb 26, 2007 | 02:50 PM
Nismo G's Avatar
Do you have 17", 18" or 19" rims? Stock or aftermarket? That could have a huge factor in it.
-sean
Old Feb 26, 2007 | 04:18 PM
Shellnyce's Avatar
I thought MREV showed like a 30hp gain on a stock revup. I have no mods so I'm not one to argue. I know I read all these dyno sheets showing MREV results. I thought a stock 298 revup put 237 to the wheels. Wouldnt the MREV put you around 250-260 to wheels without any exausts or anything else?
Old Feb 26, 2007 | 04:47 PM
Nismo G's Avatar
No, that is the most rediculous thing i have ever heard. Maybe if you had a few NOS stickers, but other than that no.
-sean
Old Feb 28, 2007 | 10:00 AM
D's06G's Avatar
stock 19's its an 06
Old Mar 2, 2007 | 12:13 AM
tac-m's Avatar
Is the 4th a one to one ratio or is it the 5th??? (I think it's the 5th)
If you did your pull in 4th that would explain the higher numbers....
Old Mar 2, 2007 | 12:16 AM
izmir41500's Avatar
G35driver Addict
4th for auto, 5th for 6mt
Old Mar 2, 2007 | 12:27 AM
Klubbheads's Avatar
U should be hitting high 13s and traping easily over 100mph at a normal track. If u can do that then the results are accurate.
Old Mar 2, 2007 | 02:39 PM
Shellnyce's Avatar
-sean
I'm not even gonna try to dig through the 90 pages of MREV crap to find the numbers.
Old Mar 2, 2007 | 02:41 PM
Nismo G's Avatar
hahah so are you trying to tell me that im wrong and that the MREV does add 30HP?
-sean
