G35 & G37, Coupes & Sedans
Engine speed at 70mph
Old Apr 13, 2007 | 07:06 PM
kako's Avatar
My engine speed at 70mph stays at 3000 rpm. Is this around normal ? Btw I have Ztube/Popcharger on a 5AT.
Old Apr 13, 2007 | 07:37 PM
ON's Avatar
ON
That seems pretty high. Mine is at 3000rpm at 80mph, but i drive a MT. I don't know if that's normal for a AT. what do you drive?
Old Apr 13, 2007 | 07:56 PM
OCG35's Avatar
I'm about 80mph at 3Krmp - AT
Old Apr 13, 2007 | 08:03 PM
kako's Avatar
Hmm.. I have a slight feeling this is due to the new intake I installed ( Ztube/Pop). I've also checked the new install and everything looks fine and tight. Unfortunately I dont remember exactly how it was with the stock intake setup. How about the rpm of you 5AT owners with Ztube/Popchagr ?
Old Apr 13, 2007 | 08:13 PM
LudwigB's Avatar
Mine 06 Sport Sedan AT is at about 3300/3200rmp doing 80mph.
Old Apr 13, 2007 | 08:26 PM
OCG35's Avatar
I have CAI w/Z-tube... I posted mine above... your intake isn't affecting your rmps.
Old Apr 13, 2007 | 08:37 PM
BayAreaRefuGz's Avatar
i fly low
i have stillen cai + ztube.....80mph@3000rpm in 6th gear.
Old Apr 13, 2007 | 08:53 PM
OCG35's Avatar
OP, when you installed you intake - did you happen to clean the throttle body or MAF sensor?.... Or even move the TB plate?
The reason I ask is the last time I had my intake off and cleaned everything (and swapped plenums and some other stuff)... my idle was real high - very high for my car... check engine light came on, rmp were outa whack... ECU reset fixed it all.
So even though the intake itself isn’t causing it, I guess it could be from the install (depending on what you did). what is you idle RMP?
Old Apr 13, 2007 | 09:12 PM
kako's Avatar
my idle is around 550 and I've done an ECU reset.
Old Apr 13, 2007 | 09:19 PM
OCG35's Avatar
is that higher, lower, or the same as it's always been?... I can't imagine it was ever any (or much) higher... Yours is a bit higher than mine but that doesn't mean it would affect your 3k rmp at 70mph especially lower than norm... what was your rmp at 70 prior?
Old Apr 13, 2007 | 11:54 PM
kako's Avatar
Unfortunately I did'nt pay attention to the RPM prior to installing new intake because everything felt normal. But now going at 70mph on the highway definitely feels like theres more engine noise. Something i noticed is when I idle there are sometimes a very very slight fluctuation in the idle RPM, but enough see it.
Old Apr 14, 2007 | 11:23 AM
OCG35's Avatar
by no means am I an expert, but like I said - the last time my intake was off (I did a bunch of stuff) my idle was much higher than norm and therefore the entire rmp were higher in normal driving condition. There is an "Idle Air Volume" ECU reset which is actually Throttle Position Learning - it didn’t fix my prob, but you might want to try it... and/or do the standard ECU Accelerator Pedal Reset Procedure (that's what finally got mine to norm - or it could have been the combo of the two I guess)... Here’s the Idle Air Volume Learning procedure (it’s out here in the forum somewhere too, it’s just easier for me to attach this than look for a link):
Old Apr 14, 2007 | 12:35 PM
cutiewolf's Avatar
3k at 80mph sometime its 28k-29k...
Old Apr 14, 2007 | 12:52 PM
JOKER's Avatar
CLUB MODERATOR
Switch to a next gear. I'll go down
Old Apr 14, 2007 | 01:26 PM
jdmeg21's Avatar
maybe there is a vacuum leak somewhere.
