G35 & G37, Coupes & Sedans
INtellikey being erased
Old May 24, 2007 | 10:47 PM
kashrahman's Avatar
just found this on autoblog:
If you have a 2007 Nissan Altima or a 2007 Infiniti G35 Sedan, you might want to keep your mobile phone in a different pocket than your car's fancy I-Key fob. The fobs, as you're probably well aware by now, enable and disable the cars' keyless ignition systems. According to Nissan, the problem is that if the fob is touched by a cellphone while a call is in progress, the software that controls the I-Key's automagic goodness could be altered or erased, rendering it useless. Furthermore, the damage is not reversible, and the I-Key simply becomes landfill fodder.
Nissan's modifying the key to correct the issue, and will provide new ones to owners once it's straightened it all out. According to the AP, this'll happen sometime in the fall. In the meantime, some dealers are stocking up on spares just in case, and you'd be advised to follow Nissan's advice and keep a little distance between the key and your phone. After all, you don't want the simple act of pressing the Start button to turn into an exercise in futility -- especially over something as mundane as checking your voice mail.
Original article here
I usually keep my intellikey in one pocket; pager and cell phone in another. I noticed once the "intelligent" part wasn't working -- pushing the button on the driver door wouldn't work; I think I had the key and pager (or phone) in the same pocket. I took the key out, and everything worked perfectly. has anyone else noticed this? Kash
Old May 25, 2007 | 12:15 AM
trey's wife's Avatar
My horns hold up my halo
And this is about the 5th post about this.
Old May 25, 2007 | 01:11 AM
Beebo's Avatar
plz close this thread!!
Old May 25, 2007 | 12:11 PM
kashrahman's Avatar
i did a search before posting and didn't find anything. sorry for trying to contribute, Kash
Old May 25, 2007 | 12:13 PM
Ca$hio's Avatar
Old May 25, 2007 | 01:16 PM
kashrahman's Avatar
glad I finally pleased someone . . . .
Hasanbaloch
Feb 29, 2024 08:45 PM
INVADER_6MT
Sep 3, 2015 01:47 AM
kashrahman
May 1, 2007 11:32 AM
