G35 & G37, Coupes & Sedans
Dealer says warranty void cause of plenum
Old Jul 19, 2007 | 11:46 PM
seung012's Avatar
Hi everyone, got a pretty screwed up situation. My car had 58000 miles on it when I took it to the dealer to get my problem checked so I still had warranty. I took it in cause I thought it was consuming a lot of oil. When I did and told them, they decided to do a oil consumption test. Turns out my car is eating quart and a half of oil every 1000 miles. So due to this I talked to the dealer's master technician, and he states that infiniti corportation will not cover the problem because the Crawford Z plenum is eating oil. Doesn't that sound nuts?! Anyone have any suggestions? If you are a licensed mechanic, please put plenty of inputs so I can print it out and show to the dealership...thinking about going to court if this continues. Any help with be great. Thanks everyone!!
Old Jul 19, 2007 | 11:56 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
put your stock plenum back on and take it to another dealer. the Crawford plenum would NOT cause the car to burn up oil.
-GP-
Old Jul 20, 2007 | 12:03 AM
g35lamd's Avatar
-GP-
^ +1
izmir41500's Avatar
G35driver Addict
i thought infiniti had a system where they note your mods and it shows up wherever you take it. maybe you can find a mod friendly dealer close by?
Old Jul 20, 2007 | 12:05 AM
RichardxG35's Avatar
man sorry to hear that bro.. i would of taken out the plenum before bring the car into the dealer... "the dealer's master technician, and he states that infiniti corportation will not cover the problem because the Crawford Z plenum is eating oil. Doesn't that sound nuts?!" no i don't think that sound nuts.. GL
Old Jul 20, 2007 | 02:12 AM
Beebo's Avatar
Have the *********** s prove it!!!
Old Jul 20, 2007 | 02:13 AM
pantablo's Avatar
there's actually a legal precedent for you to still be under warranty. I can't remember the name exactly (google is your friend) but basically they have to prove the aftermarket part DIRECTLY caused the incident to not cover it. Simly having it on does not void the warranty.
There's plenty of documentation here that would suggest Infinity also has sufficient documentation about the extent of the oil issue so that you could easily argue its a car problem regardless the swapped part. I wish I could remember the case name...
I love google. Never say I didnt give you anything, lol. Its the Magnuson-Moss Warranty Act.
more info here: http://www.dummies.com/WileyCDA/Dumm...e/id-2669.html
LOL!!!!!
Old Jul 20, 2007 | 02:20 AM
2drwild's Avatar
I have the spacer and at 74,000 miles I'm having same problem..........
Old Jul 20, 2007 | 02:26 AM
steve21's Avatar
wtf? whats this line for?
BINGO! This guy hit it right on the head. The dealer has to prove that ur plenum is causing the problem. I say u print out a copy of the magnuson moss act and shove it in their face and tell them to either prove ur mod is the problem or replace your engine. Good luck though
Old Jul 20, 2007 | 10:26 AM
TURBOTOM's Avatar
a.k.a kleicoupe
put the car back to stock and go to another dealer, make sure you do this before the warrenty is up or you are lookin at some serious $$$
Old Jul 20, 2007 | 01:40 PM
Serg's Avatar
One guy here in town that I know had his vehicle tested for oil consumption. He failed four times not only three (test required) but they asked him to go back a fourth time. Once all was done and he had failed. He got a friendly, "Infiniti should be putting out a TSB on the oil consumption issues the cars are having. At that time we will correct your problem!" Thats why they are called "STEALERSHIPS". They dont give a f&^&
Old Jul 20, 2007 | 02:55 PM
fortified's Avatar
Supposedly it's changing. Nissan typically is more open to legal mods esp. those they sanction. NISMO and usually Stillen.
It is taking longer for some Infiniti dealers to come around.
If in doubt at all, remove the mod and save yourself a headache or a long drive to another less convenient dealer. Try to get friendly with the service staff and find out what they will accept. Might be worth the cost of an oil change (bring your own oil and filter to save some money) so you become a familiar face.
My local Nissan dealer only charges me $10 for an oil/filter change. Plus they are into the cars. But can't do the warranty work.
Old Jul 22, 2007 | 03:53 PM
g45's Avatar
g45
-GP-
+100
Old Jul 22, 2007 | 05:09 PM
joeygott's Avatar
G35/350Z oil consumption problem
Don't believe MOST dealer service writers since they are trained to lie. This problem does exist. My car (2006 coupe with 6mt) had to have a new motor put in at 10k miles due to running without oil even though there was no exterior leakl. Entire new long block installed under warranty through INfiniti.
Between this problem and tire problems due to messed up supension geometry, I'm not sure just how good of a car the G is. BMW 3 is starting to look better and better.
I'm sure Carlos (new CEO of Nissan) got a great deal on some cheap piston rings and jumped at it. They should go down hard for these problems.
Nissan sales are WAY down and so is quality and rankings in Consumer Reports.
