G35 & G37, Coupes & Sedans
'03 G35 Coupe: Help Working out bugs!
Old Sep 30, 2007 | 07:37 PM
vipergts's Avatar
Recently picked up an '03 G35 Coupe. First post although I've been reading here for info since purchase. The Q's I have not found an answer to using search/other posts.
1) Does window lockout button on driver switch module have backlighting? All other door/window switches do on both sides.
2) Heated seat switch backlighting? My driver seat was not working(backlighting) so I took apart to see if LED's were replaceable. They are if part was available. When I reinstalled switch, it would not work at all! WTF!!! Disconnected pass seat switch and it stopped working as well. Double WTF!!!
3) Door window reset procedure. Driver side window worked when it wanted to. Cleaned/lubed motor as described in posts here. Window seems to work better however the adjustment doesnt seem to have much adjustment. Window doesnt come down as much as pass side. Tried several times releasing switches at different positions, but window has same drop when opening/closing door. Could someone be more specific about adjustment procedure describing when to release switches and how high to raise window before pressing reset switch and lowering window?
Thanks for any help! This site has been very helpful!
Randy
Old Sep 30, 2007 | 09:59 PM
Beebo's Avatar
1. No
not sure about the other stuff sorry
g/l
arora_g35
Apr 16, 2026 02:52 PM
laksjd84
Jul 24, 2015 05:12 PM
nervseele
Jul 17, 2015 11:21 PM
attarday
Jul 15, 2015 04:03 PM
