G35 & G37, Coupes & Sedans
Can Somebody Please Help Me W/ My G35
Old Nov 26, 2007 | 10:19 PM
onegdirty5's Avatar
Angry Can Somebody Please Help Me W/ My G35
Whats up everybody.....ok heres the problem i have with my g coupe 5at....i turn the car on and it drives fine for like 5 minutes after the 5 minutes the car shuts off on me....i restart the car and all the lights in the cluster lights up (slip,engine service soon,vdc off)...im new to g35driver so can somebody please tell me what the problem might be?....thank you
Old Nov 26, 2007 | 10:22 PM
617G's Avatar
CFW (Carbon Fiber Whore)
see if you can make it to an autozone and run an OBDII scanner to grab the codes
have you done any mods recently?
Old Nov 27, 2007 | 09:29 AM
fecurtis's Avatar
Are ALL of your gauge lights coming on?
Old Nov 27, 2007 | 11:54 AM
onegdirty5's Avatar
the car has no mods....i started the car today and it got worse....i turn it on and shuts back off without even driving the freakin thing....my car has 100,000 miles on it my father says it might be the spark plugs...
Old Nov 27, 2007 | 11:55 AM
onegdirty5's Avatar
and yea all my gauge lights are on
Old Nov 30, 2007 | 08:23 PM
Ciccio's Avatar
Loose gas cap?
Old Nov 30, 2007 | 09:16 PM
g035sedan's Avatar
sounds like it has to do with fuel deliverey to me.
Old Dec 1, 2007 | 12:39 AM
TurK's Avatar
been coming up on this question quiet a bit....if you search you will find other people in the same situation
Old Dec 1, 2007 | 12:44 AM
garry101's Avatar
might be your throttle body, i got mine replaced twice already. anywayz gl with it.
Old Dec 1, 2007 | 10:38 AM
onegdirty5's Avatar
i dont have a loose gas cap....i put gas all the time....im just goina put a scanner on it and lets see wat happens...i hope its not a major problem cause i just lost my job....oh by the way i hooked up drl's on my coupe...if anybody needs help hooking them up ask me!
Old Dec 7, 2007 | 08:41 PM
onegdirty5's Avatar
so i hooked up the scanner to the coupe and i got cmp sensor and knock sensor....can somebody please help me locate the two sensors please...cause i heard that sometimes the connections are loose so i just want to make sure...thanks everybody!
Old Dec 11, 2007 | 08:37 PM
89rodknocker's Avatar
Check for oil first sound like you dorve it with now oil and snapped the pin on the camshaft. Hopefully not. Also add some gass to the tank your gauge might be off.
Old Dec 12, 2007 | 12:09 AM
onegdirty5's Avatar
yeah i dont know about the oil but i hooked it up on the scanner and it came up with camshaft position sensor - bank 1 and the knock sensor and it says low voltage for the knock sensor.... so i cleaned the connection on the cmp sensor and it worked for a couple of hours but it came back so i ordered a new cmp sensor and the knock sensor ill clean it...its just a b*tch to get to
Old Dec 12, 2007 | 12:11 AM
onegdirty5's Avatar
hey 89rodknocker wats the pin on the camshaft?
Old Dec 15, 2007 | 05:12 PM
chowdogg's Avatar
i had a problem similar to that and at the dealership had to fix some wirrin and tighten my grounds
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
teamghost
Jul 28, 2015 04:52 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
