G35 & G37, Coupes & Sedans
Removing tire from wheel
Old Nov 27, 2007 | 06:34 PM
celwin's Avatar
Anyone ever tried removing a tire from a wheel at home? I have an old wheel in the garage and was curious if I could try to remove the tire off the wheel myself. Just a DIY I was curious in doing.
Old Nov 27, 2007 | 06:55 PM
06g35meister's Avatar
doable but hard
Old Nov 27, 2007 | 07:07 PM
GR8TG35's Avatar
I doubt very much if you can remove the tire yourself without doing some damage to the lip of the rim.....
First remove the valve stem to release all the air pressure. Then you need to break the tires bead off the rim.
Then you need to use some type of pry bar,(they have these flat pry bars most tire places used to use) to work the tire over the lip of the rim, and then work the bar(s) around the rim's lip until the tire is over the lip.
Then you repeat the same steps with the rear of the tire to remove the tire completely.
If you had a stand to mount the rim, it would be alot easier...
I would just take it to a tire shop and have them do it for you.
Old Nov 27, 2007 | 10:25 PM
TurK's Avatar
Dont be an idiot...take it to a tire shop.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
Fireman07603
Aug 9, 2015 06:00 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
