G35 & G37, Coupes & Sedans
HU and climate control porblem
Old Dec 19, 2007 | 02:11 AM
yuanchen's Avatar
Today my HU and climate control doesnt working. It seems no power or something. Cant turn on audio and adjust on climate comtrol, But when i turn on light the buttom light up. Please help thanks. Also does any know how to remove the HU whith picture ?
Old Dec 19, 2007 | 02:19 AM
Beebo's Avatar
if you have warranty take it and have the dealer replace the HU
Old Dec 19, 2007 | 02:55 AM
yuanchen's Avatar
But mine is a 03 warranty expried
Old Dec 19, 2007 | 10:10 AM
Beebo's Avatar
that sucks... they should have a TSB for it idk why they dont... so many people have this problem.. i think you should just go aftermarket because to replace the HU it will cost just as much maybe more than an aftermarket system
Old Dec 19, 2007 | 10:37 AM
Gilley's Avatar
The AC and radio share a circuit board and it is common for it to short out. You can have it repaired, buy a new circuit board, buy a used radio, or go with an aftermarket radio and double DIN kit.
Old Dec 19, 2007 | 06:16 PM
yuanchen's Avatar
Well today it get back working again. I had that problem before, it just dont work for couple days, then it works agian. I think I should check out the circuit board see what is going on.
Old Dec 25, 2007 | 01:00 AM
mhn's Avatar
mhn
Remove the deck and check your ground to your deck.... I did a dd swap and found that my ground on the harness was bad... and probably led to the same issues that i had with my stock unit.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
markbilo
Sep 30, 2015 01:33 AM
