G35 & G37, Coupes & Sedans
Steering wheel controls
Old Jan 22, 2008 | 02:43 PM
Mannyf312's Avatar
The radio controls on my steering wheel are not working after the battery was disconnected and reconected. Anyone have an idea what the cause is?
Old Jan 22, 2008 | 06:53 PM
dave's Avatar
What else did you do besides disconnect/reconnect the battery?
Old Jan 22, 2008 | 11:23 PM
OCG35's Avatar
you reset all the stations right?... I'm sure you did, but sometimes the obvious gets overlooked...
Old Jan 25, 2008 | 08:58 AM
Drox's Avatar
Newb here, just bought the coupe and my controls are not working either. What do you mean by reseting all of the radio stations? Does that help the controls on the steering wheel?
Old Jan 25, 2008 | 09:29 AM
JessNherG's Avatar
That sounds electrical. Take it in for warranty work
Old Jan 25, 2008 | 11:13 AM
OCG35's Avatar
no - what I meant is that the presets are wiped out so I thought maybe he just wasn't able to use the station set function... if you cant power on or off or anything else, then it's not what I mentioned.
Old Jan 25, 2008 | 11:19 AM
Drox's Avatar
Thanks to both of you. I will just take it in and have it looked at under warranty.
Old Jan 28, 2008 | 10:52 AM
fecurtis's Avatar
Probably a blown fuse. Easy fix thats free since all cars have spare fuses in the fuse box.
Check the manual to figure out which fuse runs the steering wheel controls and check to see if its blown. Whole process should take no more than 10 minutes or just take it into the dealer.
Old Jan 28, 2008 | 11:21 AM
Drox's Avatar
Is it a separate fuse for the Audio controls? The cruise works perfectly.
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
Gip
Aug 24, 2015 05:31 PM
kd03g99
Jul 30, 2015 11:24 AM
