G35 & G37, Coupes & Sedans
theoretical gas mileage improvement?
Old Mar 12, 2008 | 06:37 PM
xkunalx's Avatar
so while I was driving in cruise control, i shifted in to manual by accident and say that it was running in '4' as opposed to '5'....since '5' is basically overdrive, can one get better fuel economy by driving in manual mode and going into overdrive? in theory it makes sense..what do ya think?
ps im not complaining about the gas mileage...just curious..
Old Mar 12, 2008 | 06:46 PM
kevink's Avatar
In my 04, shifting into M will drop me down to 4, even though D is the equivalent of 5. So I know of no known difference between 5 in M mode, and D.
With later years, there are differences in behavior. But you don't get any higher overdrive gear in M mode.
Old Mar 15, 2008 | 10:15 PM
slim_g35's Avatar
Yeah, what happens with most manufacturer's "tiptronic" transmissions (including infinity (04's for sure)) is as soon as you change from "D" to "M" mode, it automatically drops a gear because the system assumes you are going into "sport mode".
If you're in D and doing 20mph for example, in D, you might be in D-3. When you switch to M mode, it would drop you to M-2 by default...
Old Mar 15, 2008 | 11:59 PM
officerdbag's Avatar
If you want to save gas, always drive in triptronic mode and shift to 5 as fast as you can.. the earliest you can go to 4th is at 20mph and 5th is 30 mph.
I also found a trick in the triptronic mode for launching.
Old Mar 17, 2008 | 01:28 PM
diego34's Avatar
well since we're in the subject of tiptronic can anyone show me where i can learn how to use it? do and don't etc i've never used a tiptronic let alone a stick shift so yeah.
Old Mar 17, 2008 | 01:39 PM
GeorgiaGcoupe's Avatar
What's your "special" trick for launching?
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
prinny
Nov 22, 2015 11:07 PM
Hogbone
Sep 28, 2015 06:44 PM
wow600rr
Sep 28, 2015 11:50 AM
