G35 & G37, Coupes & Sedans
MPG readout
Old May 16, 2008 | 02:44 PM
BigGrz's Avatar
MPG readout
I have the permium package without the navigation which means I can't see my active MPG. Do you guys know of an easy way to add a MPG readout to my car?
Old May 16, 2008 | 02:45 PM
Da-G-SpoT's Avatar
Good question. I would be interested in something like this. Lets see what they got.....
Old May 16, 2008 | 03:41 PM
BigGrz's Avatar
I did some research and came up with this...
http://scangauge.com/
It should work on any car after 1996, when they started requiring the onboard diagnostic output in cars.
Old May 17, 2008 | 02:55 AM
theshawn's Avatar
well you could always fill up your tank to the top reset your trip odometer.... drive it around for a while... go back fill up your tank. take the ammount of miles you've driven divided my the amount of gallons it takes to fill up your car and BAM! MPG FTW.... j/k i have the fully loaded nav MPG read out and its not always accurate one time it told me i was only doing 11 MPG!?!?! after 2 days of driving.....
Old May 17, 2008 | 04:45 PM
Da-G-SpoT's Avatar
Nice stuff, cool find! i checked ebay and found it cheap + some extras...
http://cgi.ebay.com/ebaymotors/ScanG...spagenameZWDVW
Old May 17, 2008 | 08:58 PM
Carlito's Avatar
Same price on Amazon. Good look out - thanks
Old May 17, 2008 | 10:28 PM
Dominican1NYC's Avatar
You know what sucks? My 05 Altima had this feature so I was baffled when my 05 G35 didn't have it. It's just one of those things that you want to have but isn't really all that important.
Old May 17, 2008 | 10:52 PM
mal_TX's Avatar
The nav MPG read-out is using ECU data about how much fuel is being injected to track the MPG. It should be very accurate unless it gets a bad data point, in which case it will average it out or you can reset it.
Its not like it's some silly hack or anything -- the ECU knows exactly how much fuel should be injected for the amount of air the MAF sensor says it coming into the intake to maintain appropriate air/fuel mixture.
TNRocker
Sep 21, 2015 08:36 AM
carsmacked71
Sep 18, 2015 04:13 AM
Fire0nic3
Sep 1, 2015 12:12 PM
JoeMac
Aug 20, 2015 10:17 AM
