G35 & G37, Coupes & Sedans
Need your Opinions please
Old Nov 5, 2008 | 07:59 PM
g35coupe253z's Avatar
should i get my 30k maintenance? if so its like 850+...from the dealership or should i just take it to a shop and have it done for less? as far as quality im not to sure of shops...and i feel that dealers are more safe but too pricey anyway if any1 come across this what would u have done? ur help is appreciated thank you.
Old Nov 5, 2008 | 10:46 PM
Trbulnt's Avatar
Do it yourself!! I have an X Sedan and just changed the front and read diff fluid with Royal Purple, gave her a synthetic oil change and will be changing the coolant this weekend. I will be changing the trans fluid with Nissan specific fluid once I decide if I am going to upgrade the valve body or not. It is much more inexpensive to do it yourself and you get the satisfaction of working on your own vehicle. If that is not an option than I say have a private shop quote you a price and go from there. Just make sure they quote you with the Nissan trans fluid. Good luck.
Old Nov 6, 2008 | 02:32 PM
Grav's Avatar
If you do it yourself, keep good records. Keep the receipts of all the fluids and parts you use, and keep a log of when you did what and the mileage. Otherwise, they could play games with your warranty.
Old Nov 6, 2008 | 02:43 PM
fluffy's Avatar
do everything yourself except for the flushing portion, take it to nissan instead...should cut your cost by at least half.
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
