Wheres the cup holder!?!? yea theres one on the door but i can only put bottles in it. i need one for a CAN of pop. ive searched a little bit so see if anyones made a mod of some kind, but couldnt find anything. i thought of converting the ash tray behind the shifter but not sure how much work that would be.
So if anyone has the same problem or has a solution, your help would greatly be appreciated!!!!!!
dont you have them in the middle of your center console, just move the little flap door also there should be something inside the arm rest.
Quote:
no i dont, its an '03 and all i have (from front to back) is the shifter, a little ash tray that flips up, the switches for the heated seats, and then a big storage spot that flips up but its all open insideOriginally Posted by pczavala
my 05 has one before the armrest, covered by a little slide shield. and you can pop out the little divider to have more room or something?
humm...unless its really hidden good or im just missin something lol, i cant find anything else besides the one on the door and you can only put bottles there
I actually heard the 03's were wierd. You might not have one.
EDIT: jeremy the picture you posted is from a g37
I took mine out because my elbow hits it every time I shift into 2nd, 4th or 6th.
Cup holders were such an after-thought in this car it's not even funny.
Might be. I just googled it. Almost the same in my 05Originally Posted by keff108
I actually heard the 03's were wierd. You might not have one.EDIT: jeremy the picture you posted is from a g37
Quote:
I have an 03 as well..the big storage spot thats empty that you are talking about shouldnt be empty. there is a cupholder tray that can be taken out if you dont want it so im guessing the owner before you probably took it out..Originally Posted by Gizz35
yea mine looks nothing like the picture above, but im guessin like andrewnarsi said, the owner before me probably took the removable cup holder out because it does look like something like it could fit in there, any one know where i can pick one up??
theres a piece that goes in your armrest box.. did oyu get it used? mine wa sin the trun when i got mine used and it otok me a minuet to figure otu where ti went... it drops in for cupholder and you can remove it to have like a storage box type area ( iahve 04 6mt)
yeah you must be missing the little slide that goes in the middle, which seperates the 2 cup holders
