Water in my car??
A couple of weeks ago, it rained pretty badly at night.. and when I got in my car and stepped on my break.. some cold water dripped down on my foot. ( was wearing flip flops at that time).. do You think I have a leak where my window shield
is? This has never happened to me before. Has anyone else had the same problem?
This happened on the passenger side of my car, which is a right hand drive. The grommet for the main wiring loom was loose and allowing water to come into the cabin. Lift the plastic trim pieces below the windshield, I think they're held in with plastic clips. Check to see if all the rubber plugs and grommets and correctly seated and sealing properly. I'd imagine there would be a (hopefully sealed) entry point under the windsheild on the drivers side of your car which is where the main wiring loom would enter for the right hand drive model.
I had this happen to my Grand Cherokee after a severe rain. Turns out the water drains were clogged. I'm not sure where they were (it's a work car so work paid for the repair and I wasn't involved).
marsman328
Northern California
Aug 11, 2015 07:29 PM
joedaddy1
Jul 28, 2015 02:58 PM
