G35 & G37, Coupes & Sedans
Exhaust Question (PICTURES INSIDE !!)
Old Jul 5, 2009 | 06:49 PM
j 4 lD's Avatar
Exclamation Exhaust Question (PICTURES INSIDE !!)
I posted earlier about a sound I was hearing from the G, which I suspected was an exhaust leak. (Thread can be viewed here).
So I ordered two 60 mm gaskets (one for the midpipe to muffler connection and the other for the midpipe to Y-pipe connection) from DirectTuning. Turns out they are different sizes so I had to go to Kragen and pick up a generic midpipe to y-pipe flange gasket.
So I took off the existing gaskets, one of which was in decent shape (midpipe to y-pipe), and the other one was falling apart. It was coroded, rusted, and flaking to the point where it was essentially useless.
This is the 60 mm (midpipe to muffler) gasket that was deteriorated.
This is the gasket that was in OK shape (midpipe to y-pipe) and was larger than 60 mm. I replaced it anyway.
This is one of the two 60 mm gaskets I got from Direct tuning (only used 1 cuz the other was too small).
This is the packaging from the one I got from Kragen (I installed it before I took pics).
I replaced both of them, tightened up the bolts and started up the car. It sounded ok in the driveway, but when I initially took it out and cruised at 5 mph, I heard the raspy sound like crazy, then I took it for a 5 minute spin to heat up the exhaust. I didn't hear the sound anymore but this is how it was before too.
So my question is: how long do these gaskets take to heat up and expand to create that seal between the flanges that I'm looking for? Also, what might be the cause of failing gaskets? Any other advice, haha?
Thanks in advance!
Old Jul 6, 2009 | 04:21 PM
OBG3506's Avatar
do you have to torque down exhaust gaskets bolts? if so overtightening can be the culprit.
Old Jul 7, 2009 | 06:46 AM
Dranom's Avatar
those generic gaskets kinda leak still. used that on my exhaust and i can still see some black stuff on the gasket.
Old Jul 7, 2009 | 09:32 AM
pwebb's Avatar
you can clearly see that the old gasket was leaking.
use oem stuff.
Old Jul 10, 2009 | 06:50 PM
j 4 lD's Avatar
anyone else?
I still hear the sound and its been a few days...
Old Jul 10, 2009 | 07:09 PM
BloodlineG's Avatar
i just replaced mine like a week ago. cause i noticed that my g didnt have that "g" sound. i was missing a gasket at the midpipe. replaced the two after the cats. and i havent replaced the one at the muffler. the two by the cats are the same the midpipe one is different and the one at the muffler is like a ring. no problems after i replaced them, just use oem. ther not that expensive. like $14 each or something the ring one is more expensive though.
Old Jul 10, 2009 | 11:41 PM
gary c's Avatar
Having been thru 5 different exhaust systems there's no better gaskets than the OEM (factory) gaskets. Stores like Kragen sell junk compared to what came on your G....real live actual junk! Next time you need gaskets stop by your Nissan dealership and buy quality parts that will last.... There's no need to torq down the exhaust bolts/nuts, align the gasket and bring the bolts/nuts up even then swing away! This is where I enjoy using an impact gun, can't hurt a thing!
Gary
Old Jul 12, 2009 | 12:32 PM
j 4 lD's Avatar
^^ But do you think that nasty raspy sound is the culprit? I don't want to down there again and replace that gaskets only to find out the noise is coming from some place else. It is a loud, raspy sound that I hear when the car is moving, slow and fast.
Old Jul 13, 2009 | 10:53 AM
pwebb's Avatar
have a helper put rags over the tips. you will expose the leak quickly.
Old Jul 29, 2009 | 10:13 PM
j 4 lD's Avatar
^^ Will I see fumes or just hear the leak?
I went to the stealership a and picked up a replacement gasket for the generic POS I got at Kragen. I'm gonna put it on this weekend and hopefully this will take care of things. The scratching, raspy sound has only gotten worse since my last post. If this doesn't work, I won't even be confident that the problem is related to my exhaust, although it sure sounds that way now.
Any advice?
Old Jul 29, 2009 | 10:21 PM
j 4 lD's Avatar
Gary
Yea I just picked up 1 gasket ($15!!) from Nissan and hopefully it will do the trick. It looks like it's built differently than the Greddy gaskets or the ones from Kragen. Its mage up of 3 or 4 thin layers of metal that are not compressed.
This is not the best view of it but it's what it looks like.
I just don't know how well this will work with one side being the OEM exhaust and the other side being the AM exhaust.
Will update as soon as I throw it on and test drive the G.
Muski_G
Dec 1, 2023 11:11 AM
Th611
Oct 27, 2015 03:48 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
