G35 & G37, Coupes & Sedans
castrol syntec >> mobil 1 v.withUOA
Old Jul 12, 2009 | 07:41 PM
Blue Dream's Avatar
I drove ttrank's car solo
I use Castrol Syntec and it works great. No need to change, and I'm glad to see these results. Makes me like it even more!
Old Jul 12, 2009 | 07:59 PM
ShanesG's Avatar
which M1 was it???
Old Jul 13, 2009 | 08:35 AM
uf20wop's Avatar
Originally Posted by ShanesG
which M1 was it???
5w-30
Old Jul 13, 2009 | 09:35 AM
uf20wop's Avatar
Originally Posted by gary c
I used Mobil 1 for 125K miles on my last Z, it's still on the street running great and I never had to make any serious repairs except normal maintance. That alone should tell you that Mobil 1 is damn good synthetic oil! Screw the tests this is real life experience....Plus, when my rear main seal failed they pulled my oil pan it was as new inside with no residue/gunk at 117K miles. This is only possible with quality synthetic oil....
Gary
i'm not saying m1 isn't a good oil, it's fine, and i ran it forever in my se-r
but from the tests, it's clear syntec just performs better, under the exact same driving conditions and the same exact engine, the wear levels were lower and there were higher levels of anti-wear additives.
considering m1 and syntec cost the same, i think syntec is the way to go
Old Jul 13, 2009 | 09:43 AM
gary c's Avatar
Originally Posted by risingson
i started using castrol syntec last year and i put 0w-30 in.. i dont remember my research last year, but i concluded that would be the best to put in my car.
Different weight oils work better in areas like yours where the winter temp dips well below freezing. When you consider summer driving you would be better off just using what Nissan recommends 5W/30 all year.
Gary
Old Jul 13, 2009 | 11:44 AM
ShanesG's Avatar
Originally Posted by uf20wop
5w-30
Conventional? Synthetic? Extended Miles Synthetic?
Old Jul 13, 2009 | 11:54 AM
BostonG6spd's Avatar
I use German Castrol
Old Jul 13, 2009 | 11:55 AM
LightsOut's Avatar
SIETESG
I have always used castrol syn. my car loves it. Recently just tried that castrol syn. gold bottle and my car just feels stronger... this is all on butt dyno.
Old Jul 13, 2009 | 12:04 PM
G U LATER's Avatar
I have been using Castrol since I got my car and I always loved it.
Old Jul 13, 2009 | 01:04 PM
uf20wop's Avatar
synthetic 5w-30
not the extended performance or advanced fuel economy, just the regular synthetic
https://www.mobiloil.com/USA-English...l_1_5W-30.aspx
uf20wop's Avatar
i would try it, but i can't find it anywhere
Old Jul 13, 2009 | 01:21 PM
Swivel's Avatar
Moderator
UOA is the only valid means of comparison, IMO. Thanks for posting this.
RADIOGUY21's Avatar
what kind of oil filters did you run for both tests?
Old Jul 13, 2009 | 02:37 PM
thescreensavers's Avatar
Mr.202?
ok so we can conclude that
Castrol Syntec 5W-30 > Mobil 1 5W-30?
I live in FL like the OP so Ill have similar temps.
Old Jul 13, 2009 | 02:41 PM
  #30
LightsOut's Avatar
SIETESG
assuming both were syn. then there wouldnt be really a comparison
