G35 & G37, Coupes & Sedans
oil consumption
Old Sep 19, 2009 | 05:13 AM
w0lv3121n3's Avatar
oil consumption
hi
i drive a 2004 automatic g35 coupe
i found out that i have oil consumption issue and currently out of warranty.
Could i use the car with no major issues? just put it in oil when its low?
would it get worse and cause major problems in the long run?
thank you
Old Sep 19, 2009 | 06:37 AM
code2424's Avatar
Well your only option is to drive it until it falls apart. But wow it's very rare that oil consumption is on a 2004 automatic. You should be able to get by if you keep the oil at peak.
Old Sep 19, 2009 | 08:08 AM
officerdbag's Avatar
Start looking for a good deal on a new motor.. Thats just ***** dude.. I have oil consumption too with my extended warranty just about to expire.. So happy I bought it, saved my ***.
Old Sep 20, 2009 | 01:58 AM
OG35Driver's Avatar
Cool Oil Consumption
It is my understanding that the consumption is from the rings on the pistons going bad thus causing blow by. I drive an 03 and I didn't start having any issues until I started adding the bolt on mods, exhaust, pulleys, pop charge, plenum spacer, etc... Can this be fixed with new piston rings and or having the engine rebuilt? If rebuilding is the way to go I am thinking of using the NISMO low compression pistons, rings and connecting rods and adding the NISMO cams too for max HP...
Old May 19, 2010 | 06:10 AM
fatlip's Avatar
Yeah i was wondering the same thing about an engine rebuild. If the rings are the ones causing the oil problem can i just rebuild the motor with better rings?
Old May 19, 2010 | 03:47 PM
jibberjabbers's Avatar
Would your insurance company be willing to cover the cost of a new motor? Never know, call them and see.
Old May 19, 2010 | 04:31 PM
vp-g's Avatar
I think I might be having the same issue having the dealer do the OC on my 03 6mt. What does 1qrt loss on the dip stick look like?
Old May 19, 2010 | 10:53 PM
BlkCoupe's Avatar
OP, exactly how much oil are you consuming in how many miles?
Old May 19, 2010 | 11:32 PM
fatlip's Avatar
Yeah what does that look like? Pics anybody?
Old May 21, 2010 | 01:22 AM
Mississaugag35x's Avatar
+1 on that. for example a litre every 3000 miles isn't a problem in my opinion as long as the consumption doesn't increase with time and your compression is good.
Old May 21, 2010 | 08:42 AM
vp-g's Avatar
is 1qrt loss half way between H and L mark on the dip stick?
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
