G35 & G37, Coupes & Sedans
Help with sprint booster install
Old Oct 10, 2009 | 07:57 PM
Blue Dream's Avatar
I drove ttrank's car solo
Maybe has something to do with you being an 03??
Old Oct 10, 2009 | 08:04 PM
4DGS's Avatar
That's what I was thinking but the sprintbooster site says 2002-2007
Old Oct 10, 2009 | 11:12 PM
SUPER20G's Avatar
I believe they make a different unit for the sedan's. Mine went in easy with no hassle at all.
Edit: Only the G35X were different.
Old Oct 11, 2009 | 12:04 AM
4DGS's Avatar
Yea exactly so why doesn't mine fit???
Sprintbooster has lied to us all!!!!!
Old Oct 11, 2009 | 12:07 AM
SUPER20G's Avatar
I love mine if it makes you feel any better/gives you something to look forward to.
Old Oct 11, 2009 | 12:11 AM
4DGS's Avatar
I'm just frustrated a company of this size selling a $300 circuit board covered in plastic doesn't know what they are really selling....
Old Oct 11, 2009 | 12:22 AM
SUPER20G's Avatar
Who did you purchase it from? Where are you trying to install it? I'll see if I can help you.....
Old Oct 11, 2009 | 12:30 AM
4DGS's Avatar
I WAS going to buy it off another member on the board here.
I removed it from his car myself in full working order. Went to my car and plugged it in but it wouldn't make the click to clarify it was in. The plastic pins(not the metal ones) in the male end mounted on the pedal, appear to be different than the ones on my friends coupe.
Tried starting the car and giving it gas without it clicking and I had no throttle.
After quite a few tries I turned the car back on with normal throttle plug in to see if it may be something with the throttle on my car and not the SB. It then drove my car to a very high idle. 2000 rpm, then slowly dropped down into 1500. It didn't go back to normal 600ish idle until after I had left and got gas.
The SB went directly back into my buddies car without a hitch, very smooth going on and off, very unlike mine witch was 100% the opposite.
I don't understand....
Old Oct 11, 2009 | 12:35 AM
SUPER20G's Avatar
Is your friends car a 6mt or 5at? The same question goes for your car as well.
The reason I ask is that you cannot put a 6mt unit into an auto........
Old Oct 11, 2009 | 12:45 AM
4DGS's Avatar
Both 5AT.
Old Oct 11, 2009 | 12:56 AM
SUPER20G's Avatar
Found this on one of the other threads:
Quote:
Originally Posted by Metalp3n
Any news if this will work on the early 03, doggy-door, first gen sedans? I know that most ECU mods do not work with my ECU unless they're spliced in as the connector pieces are completely different.
Answer:
It plugs into the throttle position sensor on the pedal, not the ECU connector. So, yes it will work on an 03 sedan.
Old Oct 11, 2009 | 01:03 AM
Stiker181's Avatar
I got this to work now. You can tell the difference.
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
