G35 & G37, Coupes & Sedans
Help my 20's in the rear are bugging out
Old Oct 5, 2009 | 11:15 PM
stevedrape's Avatar
04 g35 coupe cambers in rear bugging out. I am sure this is a common question, but my g's rear wheels are bowing out like most nissan and BMW vehicles do over time. I just went from stock 18's to 20's and the tire shop was able to tow them in a little. They recommended I buy a camber extension to get the wheels perfectly straight. For as much as I just slapped on wheels and tires, i don't wan them to wear funny nor do I like the look of uneven wheels. The dealer wants $500, but somebody told me to check Stillen. What is this part actually called and where is the best cost effective place to get them. thanks for your help. Steve
Old Oct 6, 2009 | 09:03 AM
uf20wop's Avatar
http://www.g35parts.com/G35-350z-Sti...r-p/308365.htm
Old Oct 6, 2009 | 09:06 AM
OBG3506's Avatar
I like the squatting look myself!! Depending on how wide your tires are, if you straightened them up wouldnt they scrub without a fender roll?
Old Oct 6, 2009 | 12:18 PM
stevedrape's Avatar
Thanks for the website. This is exactly what i was looking for.
Old Oct 6, 2009 | 12:24 PM
parhamm1's Avatar
Steve,
Go into the marketplace here and look in the vendor section for SPC camber kits. These are the kits you want and you'll be spending a good amount less for these kits then others. They can get you close/or to zero. Just the rear kit is around $180 and this will straighten those rear wheels back up and fix an uneven wear issue. Hope this helps.
Matt
Old Oct 7, 2009 | 04:50 PM
stevedrape's Avatar
Thanks Matt! I found a few on ebay, but they look like imported cheap copies. When you pay $65 for a pair you wonder how long they will last on Los Angeles nasty roads. I would rather pay a little more with peace of mind. "You get what you pay for".
Old Oct 9, 2009 | 11:15 AM
gary c's Avatar
Camber/Toe correction....!
Stillen does make quality merchandise for our G35s but it pays to watch our own MARKETPLACE under vendors for the same items at a much better price. Stay away from eBay junk when buying parts for our cars, the risk isn't worth it especially suspension pieces!
Gary
rezendvous420
May 31, 2020 01:26 PM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
nervseele
Jul 17, 2015 11:21 PM
