G35 & G37, Coupes & Sedans
At what psi do the TPS kick in and throws a warning light? (!)
Old Nov 23, 2009 | 05:01 PM
jibberjabbers's Avatar
Anyone?
Old Nov 23, 2009 | 05:09 PM
DRG35MIA's Avatar
Mine usually goes off when one of the tires has less psi than the others. Don't know the exact number though. I keep my tires at 34 psi; when I go to check the pressure, after the light goes off, it always reads unbalanced / lower on at least one tire.
Old Nov 23, 2009 | 05:12 PM
soundmike's Avatar
It depends. At least on the V36, the FSM hints at being able to set the trigger at particular pressure points.
Old Nov 23, 2009 | 05:56 PM
teamspink20's Avatar
mine goes off daily almost. i was talking to a few infiniti techs and apparently it happens pretty often. i keep mine at 32 and that damn light comes on everytime it rains or when its real cold or hot. and i always check the pressure and its always on 32 or 31 when the lights on so i gave up checking. im about to put a piece of tape over the light on the dash
Old Nov 23, 2009 | 07:17 PM
OCG35's Avatar
somewhere between 20 and 25...
Old Nov 23, 2009 | 07:54 PM
accordfreak's Avatar
29psi
Old Nov 23, 2009 | 08:43 PM
pwebb's Avatar
high 20's I believe. 28, 29...
Old Nov 23, 2009 | 09:08 PM
Frankieg35's Avatar
I keep my tires at 35 psi my light usally comes on at 29-30 psi..
Old Nov 24, 2009 | 03:53 AM
pfarmer's Avatar
Originally Posted by jibberjabbers
Anyone?
5 psi less than setpoint.
Old Nov 24, 2009 | 10:39 AM
eurodre's Avatar
^^+1
Old Nov 24, 2009 | 11:33 AM
blazeplacid's Avatar
I dont have the TPMS anymore becasue of new wheels
The TPMS only comes on when I drive long distances. Usually over an hour. The (!) will lgiht up, but then go away later.
I didnt bypass it or do anything, just works that way in my car.
I didnt swap the TPMS into my new wheels either
Old Nov 24, 2009 | 01:12 PM
OCG35's Avatar
Originally Posted by accordfreak
29psi
not mine.
Old Nov 24, 2009 | 01:14 PM
BonBG35's Avatar
mine just turned on for the first time. i measured and all my tires were at either 28 or 29.
Old Nov 24, 2009 | 01:16 PM
loki05's Avatar
mine comes on at 28.5 psi
Old Nov 24, 2009 | 02:11 PM
pfarmer's Avatar
TPMS works at or above 16 mph.
