Do Z350 revise shocks work with any after market spring?
I currently have the revised Z350 springs/shocks on my sedan. The rear spring is rated higher than the front springs so my rear end sort of moving around more than I would like. I am thinking of using springs that have the same ratings on both front and rear and hopefully the handling will be slightly more neutral.
Is it possible to keep the same Z350 shocks and just used some good after market springs?
The Z shocks were designed to be tuned for the springs they are tuned with. ie.. oem Z springs. They aren't designed for spring rates higher than what they were originally paired with.
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
