G35 & G37, Coupes & Sedans
engine break-in question...
Old Dec 29, 2009 | 11:08 AM
fresh_06'G35's Avatar
ok so i had my longblock replaced under warranty at riverside infiniti about a month ago due to oil consumption. i know the TSB says wait 1200 mi. before going over 4k rpm and dont go WOT. im at 1100 so im eager to get back on the throttle but im tryin to play it safe. so how many of you with engines replaced under this tsb have just gone "***** out" after the initial break-in or should i still be following those guidelines for another couple thousand miles or atleast until the first oil change? also should i do the oil change earlier due to break-in material making it into the oil?
i just miss that chirp every once in a while
any input is appreciated
Old Dec 29, 2009 | 11:13 AM
willis555's Avatar
If I were you, I would wait. If you follow the guidelines, nothing will go wrong with the engine after the break-in. But, if you don't follow the guidelines, then your engine could have problems down the road. Just my opinion.
Also, the longer you wait to get back on the throttle, the more exciting it is once you are able to.
Old Dec 29, 2009 | 11:23 AM
ive followed the guidlines until now (1100 mi.) but if i were at say 1500-2000mi and wanted to get into the higher rpms would there be any resulting damage or is the engine considered "broken-in" already?
Old Dec 29, 2009 | 11:40 AM
willis555's Avatar
If you were at 1500 miles, then you would be past the guidelines, right?
Old Dec 29, 2009 | 11:41 AM
yes indeed.
Old Dec 29, 2009 | 11:58 AM
willis555's Avatar
Then I don't see why you wouldn't be able to drive hard after 1200 miles.
Old Dec 29, 2009 | 12:49 PM
Mustang5L5's Avatar
Def change the oil at least once before you start driving it moderately hard.
Old Dec 29, 2009 | 09:34 PM
gary c's Avatar
I think it's time to change oil and filter and drive that new block like you normally would, just don't be obusive....use Mobil 1 5W/30 and their oil filter too....
Gary
Old Dec 30, 2009 | 12:35 AM
ok thanks for the input i guess i was just being too cautious will change the oil sometime after new years and put my HKS back on and be one happy motha ****a.
Old Dec 30, 2009 | 10:31 AM
V35 Skyline GT's Avatar
6MT Coupe
Yeah change your oil and get most assembly lubes and metals out (takes about three oil changes to get that all out).
After 1200 I say yes you can step it up a notch, but be careful. Rings are NOT 100% sealed/seated yet at 1200 miles. In other words, don't red-line it quite yet, but some WOT's are okay under 5K rpm. UOA's will tell you when rings are 100% ready and can safely go ***** to the wall without harm.
Old Dec 30, 2009 | 12:08 PM
^thanks i will still be careful after 1200, no redline shifts or nothin until probably after the third oil change which by then i hope the rings will be seated.
Old Dec 30, 2009 | 02:55 PM
SxSkyLinexS's Avatar
did riverside infiniti ask u for any previous records of oil changes u did @ riverside infinti?
Old Dec 30, 2009 | 10:19 PM
nope, i had taken my car to them at 30k for a 30k service and went back for an oil change and to begin the OC test at 35k. other than that i did all the previous oil changes from 15k-30k. i bought the car with 15k on it.
Old Dec 30, 2009 | 10:24 PM
^ so u had ONE oil change from them (in order to ensure you weren't doing it on purpose for a new engine) then began testing?
did u buy the car with the warranty already on it or what?
Old Dec 30, 2009 | 11:04 PM
^ ya pretty much, the 30k service included trans and diff fluid changes as well as an oil change but 1 oil change after that which was the test and i had my new engine. when i bought the car in 08 it was still under its original factory warranty of 4yrs 60k.
