G35 & G37, Coupes & Sedans
Ecu reflash
Old Jan 8, 2010 | 09:34 PM
danielrhine's Avatar
Ecu reflash
I am wondering if sending my ecu in for a reflash is really worth it. I have headers, full true dual exhaust, short ram intake, track pipes and a 1/2 in. iso thermal spacer.
Old Jan 8, 2010 | 09:41 PM
silver g's Avatar
Yes it is...the reflash will get your mods actually working for you. Call Technosquare.
Old Jan 9, 2010 | 06:44 AM
Blue Dream's Avatar
I drove ttrank's car solo
Osiris /thread
Old Jan 12, 2010 | 02:03 PM
1blualti's Avatar
just got the osiris reflash (along w/ gettin it dynoed), and gained 11 hp and tq along with a much smoothe powerband with just intake and spacer...
well worth the money...get it...
Old Jan 12, 2010 | 02:34 PM
thats not bad but what mods do you have done and how much did everything end up costing?
Old Jan 12, 2010 | 03:31 PM
1blualti's Avatar
i only have intake (popcharger w/ z-tube) and iso thermal spacer...i had 242 to the wheels on a mustang dyno baseline and left with 253 to the wheels...
ended up costing me $500 for the tune and dyno time...
Old Jan 12, 2010 | 04:51 PM
NotPopsG35's Avatar
Definitely worth it IMO. Take advantage of the mods you have!
Old Jan 12, 2010 | 07:40 PM
yogi41's Avatar
I would say it's definately worth it! you're probably running a bit lean with all of those breather mods. If you can find a place I would get a dyno tune.
Old Jan 13, 2010 | 12:17 PM
NotPopsG35's Avatar
I wouldn't say he is running lean necessarily, since the ECU makes adjustments based on the reading the sensors give it.
However, if the ecu is flashed to already provide the additional fuel to compensate for the air inside of having the ecu make the adjustments, then the system is that much better.
Old Jan 13, 2010 | 07:48 PM
MJ-G35's Avatar
OP if theres not a place to take your car, I know you can take yours out send it to Greg or Ryan at Injected Performance and they with re-flash it and send it back.
Old Jan 20, 2010 | 02:41 PM
ieatstreetsquid's Avatar
Worth about 7-10rwhp. I had Altered Atmosphere flash my '03 Z. I had JWT pop, kinetix plenum, UR pulley, top speed headers and injen exhaust. Put me right around 260rwhp. I don't know how much the flash costs these days, but it was expensive when I got it done ($700?)
Old Jan 20, 2010 | 04:22 PM
In order to get a dyno tune it is going to cost me around 1100 if not more because i have to buy an access port and then pay for the dyno tune. If I do a manual reset of the ecu I should be able to get a little more out of it right.
Old Jan 20, 2010 | 08:01 PM
iamjessele's Avatar
if i were to get a ecu reflash/osiris tune . where can i get it done other then technosquare in CA? . im from MS ..ms ftl
Old Jan 20, 2010 | 08:20 PM
1blualti's Avatar
^^im from LA i had to drive to texas to get it done...i believe forged performance or z1 motorsports (or something) might be closer to you i believe its in alabama...
Old Jan 20, 2010 | 08:29 PM
iamjessele's Avatar
oh okay thanks. well ill do some research see what i can find in alabama..i just wasnt sure on the location of any tune shop
