G35 & G37, Coupes & Sedans
Clutch problems!
Old Feb 2, 2010 | 03:34 PM
ockubby's Avatar
Clutch problems!
I need a new clutch for my 2004 g35 coupe. I went to the dealership in tustin and they told me it would be $1900. My car has 40K miles. what should i do? Can i get it fixed for cheaper and where? thanks
ockubby
Old Feb 2, 2010 | 03:47 PM
tragedycat's Avatar
You can get a quality clutch and flywheel set for about $750 shipped from one of the vendors here. Take it to a reputable shop in the area and you'll make out for about $1200 in all.
$1900 for just a clutch and install is crazy, tell them to to cut that in half and maybe you'll consider it.
Old Feb 2, 2010 | 05:07 PM
MJ-G35's Avatar
JWT clutch/flywheel combo.....or ACT
The ACT is a little more expensive, but from what I have heard from a reputable sponsor and a person I trust is that the ACT combo is better.
Just my .02
Old Feb 3, 2010 | 01:18 AM
3XaCharm's Avatar
if you're going to replace your flywheel since there is no better time then having your tranny dropped and you're looking for a good flywheel you should consider a nismo one. They're about half the price as that dual weighted oem flywheel and weigh a bit less. Has a little bit of a rattle though from around 1k-2k rpms but not nearly as bad as some of the lower weight aftermarket flywheels.
I got an oem clutch though and don't remember a lot of the research I did on them back then. If you can bring yourself to trusting a shop outside of the dealership, cheaper labor on a 10 hour job always helps
11bEMT
May 27, 2022 03:13 PM
zcherub
Aug 30, 2015 05:04 PM
NemesisGee
Aug 11, 2015 07:10 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
