G35 & G37, Coupes & Sedans
Canyon Run with S2000 and New S4 and concern
Old Apr 3, 2010 | 04:59 AM
hyunkoon's Avatar
I did Canyon Run with S2000 and New S4 and it was a quite good experience.
When I was in S2000:
This car corners like a blade. Never seen a car with this much precise cornering. Even at fast cornering speed, the car seemed to be controlable.
The power was not bad at all, after 6000RPM, I felt just same power level as my G.
When I was in New S4
This car is very stable at corner. It was not sharp as S2000 but it had full of traction and car motion was very predictable.
The power level was great. It snaps heads and it seemed to have more power than 330HP as claimed.
When I was in My G35c AT
Hmmm...
Body is heavy, nose is heavier.
It seemed to have some traction by 275 and 295 Nitto Invo and aid from sway bars but Body rigidity and suspension could not match.
I felt very unstable at corners compare to those guys above.
Gear shift between 2-3 is instant but 1-2 is really slow and always hit the rev limiter even I shift at 5900RPM
Nitto Invo
This tire definately needs a warming up to get it work.
After little bit of warming, it is very predictable and good traction.
But after some point, it becomes hard to predict its traction.
Do you guys think I need suspension upgrade?
Old Apr 3, 2010 | 06:27 AM
KSWAY's Avatar
Don't expect your G to handle like the S2K.
Old Apr 3, 2010 | 07:10 AM
G35sportsedan's Avatar
If you want your G to handle better then a suspension upgrade would be a great way to start
Old Apr 3, 2010 | 10:08 AM
gary c's Avatar
The only Nissan I ever had that would out corner the S2K was my '92 300ZXTT. Corners were flat without any body lean and the Michelin's never talked back regardless of the speed or corner. I've up graded my G35 with everything available and still haven't achieved the Zees cornering ability....
Gary
Old Apr 3, 2010 | 11:27 PM
parhamm1's Avatar
Yeah you're going to be hard pressed to beat out the cornering of an s2k. They're great cars to drive around the twistys.
On another note. How do you like the invo's? How's the noise on them? I'm going to be picking up a set of tires soon and was considering these. I just want something quiet that will give me decent performance and some good life. I'm coming from KDW2's and they delivered extremely well in the performance department, but failed miserably in the noise department. LMK, thanks man.
Old Apr 4, 2010 | 12:53 AM
STCLAIRWEST's Avatar
S2000s are like go karts and they are so fun to drive
Old Apr 4, 2010 | 01:14 AM
hyunkoon's Avatar
Invo is really quiet. Noise level is just similar to regular all season tires.
and It is good in rains too.
But it really sucks on wet glass haha.
Old Apr 4, 2010 | 02:13 AM
parhamm1's Avatar
Good deal man. I appreciate the review.
Old Apr 4, 2010 | 01:10 PM
BlkCoupe's Avatar
No offense man...quiet and in the first post quite.
Old Apr 4, 2010 | 01:52 PM
hyunkoon's Avatar
Thank! fixed
Old Apr 4, 2010 | 02:25 PM
lakerschamp2000's Avatar
i have seen many guys traded their g35 coupe for s2000 for this reason, you should too if your in autocross or cayon run...
Old Apr 4, 2010 | 02:44 PM
pattyskin's Avatar
An s2000 is a 2 seater and is made to take corners and not have tons of creature comforts.
The G35 is a 4 seater luxury car designed to perform decently well while providing a high level of comfort.
You will not corner as well as an S2000 with a G35.
My 240sx has coilovers, sway bars, strut braces, delrin bushings, subframe braces, shock tower braces, and tons of weight reduction. It probably corners about even with an s2000. They corner very very well.
Old Apr 8, 2010 | 02:34 PM
Infiniti_Energy's Avatar
S2k is way lighter and smaller then a g35, cant expect it to handle as well.
Old Apr 9, 2010 | 12:04 PM
marcinr's Avatar
20 Year Member
I doubt the OP expected his G35 to corner like an S2000, but our cars are numb and twitchy when cornering anywhere near the limit. Other heavy cars seem to transmit their intent better; for instance, I've driven BMW 330i, 335i, Audi S4.
I own the G35 sedan, which is less nose heavy than the coupe, and it still feels nose heavy in turns. I've had it at the track, and the cornering limit is pretty high, but it feels "off" in a way that's hard to describe. In the other heavy cars that I've mentioned, you get feedback as to what's happening, you can feel the tires starting to slip, and you can adjust. In the G, it's numb. The car corners fantastically when the suspension loads up, but it takes longer to load up and doesn't give you that feedback that lets you get closer to the limit. I'm sure aftermarket suspensions will do better.
Great handling comes partly from suspension and tires and partly from lightness. Cars are getting heavier over time, so the handling suffers.
Old Apr 9, 2010 | 09:38 PM
PublicEnemy's Avatar
High level of comfort? What G35 are you driving? Mine rides like a rock.
