G35 & G37, Coupes & Sedans
VDC Light On- Slipping and Jerking
Old Apr 5, 2010 | 10:05 PM
rr0_999's Avatar
I have a 2003 G35 Coupe. The VDC light is on and when I make a U-Turn, it is jerking and slipping. the car is stalling and jerking when i am making a u-turn. The car has a 19" rims. Please advice for a solution and explanation why it is doing this. Thanks
Old Apr 5, 2010 | 10:51 PM
Pk_g35's Avatar
I had the vdc and slip turn on for like coupe days in a row it was due to the brakes and fluid for me, make sure ur brakes arent worn out cuz that's what turns it on. As for jerking you might have tranny issue, I read before someone had the vdc issue and dealer said they need a new transmission but it was an automatic g35......hope that helps
Old Apr 6, 2010 | 12:47 AM
Deepdiver's Avatar
check and make sure your brake fluid is filled to the full line.
Old Apr 6, 2010 | 07:00 AM
Blue Dream's Avatar
I drove ttrank's car solo
Did you recently replace your tires and/or rims? What size tires are you running?
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Luisgalvan33
Jul 19, 2018 08:16 PM
MsFitFern
Aug 9, 2015 02:58 PM
Luisgalvan33
Jul 28, 2015 05:37 PM
