G35 & G37, Coupes & Sedans
Would the Dealership charge for this? If so, how much?
Old Aug 9, 2010 | 11:48 AM
DRKNYT's Avatar
What's up guys. Having a little problem with my front right tire. Either my brakes are going bad or I have a bad wheel bearing. I'm hearing a little whistle/grinding noise when I step on the brakes. Initially, I thought it was the bearing because it was making this noise slightly before and actually went away when I stepped on the brakes. I wanted to take the wheel off myself but realize the wheels locks are on as I don't have the key. If I take it to an Infiniti dealership or maybe even Nissan, would they take the wheel lock off for me and diagnose the problem perhaps free (longshot)? Or am I better off getting them to take the wheel lock off and taking the car to another automotive shop where they can take a look at it? I had ordered a hub assembly last week thinking that was the problem and was going to try changing it myself but I couldn't get the wheel lock off. Thank God I didn't have a flat. But what do you guys think I should do?
Old Aug 9, 2010 | 03:59 PM
DRKNYT's Avatar
*bump*
Old Aug 9, 2010 | 04:34 PM
jibberjabbers's Avatar
Why don't you call a local dealership and find out?
I'm guessing your are no longer under warranty so yes they will charge you.
Old Aug 9, 2010 | 04:47 PM
DRKNYT's Avatar
correct, i'm no longer under factory warranty. But they'll charge to remove the wheel locks and place on regular nuts?
Old Aug 9, 2010 | 05:39 PM
Blue Dream's Avatar
I drove ttrank's car solo
Discount Tire removed a stripped lock for me for free a while back. Rolled in and was out in 5 minutes. Ask around, but I'd definitely avoid an Infiniti dealer on this.
Old Aug 9, 2010 | 05:58 PM
yogi41's Avatar
I'm out of warranty, and I had to remove my wheel locks and the dealership did it for free. I would call your dealership and see if they can do the same for you. However, I did have to wait 2 hours for them to do something that probably takes 5 minutes.
Marlin84
Apr 1, 2020 12:52 PM
