G35 & G37, Coupes & Sedans
New Smog check Procedure in CA
Old Oct 19, 2010 | 11:33 PM
Silencer_0's Avatar
^ You mean like registration? Hahaha
Old Oct 19, 2010 | 11:35 PM
eurodre's Avatar
^^lmfao no kind of like the toll paid to drive on toll roads on TOP of registration
damn you logic!
Old Oct 20, 2010 | 12:33 AM
kday's Avatar
What?.. This doesn't even make sense. All cars that are 96+ (obdII) already hook up to smog machines through there OBDII ports. By not having to do tail pipe emissions they're only making it easier to counterfeit smogs! Whoo hooo!
Oh and what many of you may be unaware of is "Catback" exhaust systems have absolutely nothing to do with smog. Anything and everything from the Cat on forward is emissions related. So in theory you don't even need to have a muffler installed to pass smog.
source: smog tech for almost 2 years and counting.
Old Oct 20, 2010 | 01:53 AM
eurodre's Avatar
^^so essentially this is for those who have their custom tunes? as for us (me in the future) who have any kind of modified cats or none would just need to throw some cats on and go do our thangaling?
Old Oct 20, 2010 | 09:44 AM
Mustang5L5's Avatar
Yes.
Do any of you guys have an obd2 scan tool? Does have the state obd2 test function? If so, it will tell you if your car will pass.
All the system does is look for a check engine light, and look to see if certain diagnostic monitors are complete. It doesn't actually run a true sniffer test.
You really just need o worry about visual, but if your check engine light is not on you are good.
Old Oct 20, 2010 | 09:55 AM
HangUp n' Drive's Avatar
If I understand the newspaper article, CARB currently requires a tailpipe direct measurement (sniffer)? What they are proposing is using ODBII on 2000 year models and newer. If the cars ECM (computer) says it's good, you are good to go. If your cars are not throwing codes you will probably be OK, provided they don't do a detailed visual inspection. Some of you may require O2 simulators to satisfy the ECM. I don't think it's going to be that bad.
Old Oct 20, 2010 | 10:35 AM
bigballer8's Avatar
awesome thanks for clarifying.
Old Oct 20, 2010 | 12:38 PM
ThickG's Avatar
Originally Posted by terrycs
Now if they only get rid of the visual check ...
That's my thought! I'm not worried about passing the ECU test, but the visual test is the pain.
Old Oct 20, 2010 | 01:04 PM
bigballer8's Avatar
if i put my HFC on guess i wont pass visual test will i?
Old Oct 20, 2010 | 02:27 PM
eurodre's Avatar
what if i go to glendale at a smogcheck owned by an armenian male , will he do a visual check?
Old Oct 20, 2010 | 02:44 PM
The Stimulation's Avatar
Even if he does, you'll pass. That unibrow will cover his view on a lowered car.
Old Oct 20, 2010 | 02:48 PM
eurodre's Avatar
i know a spot on colorado and chevy chase near burger king and the guy is super sick but dear God if and when i have to take the g in there but its ok they will understand im sure he has a friend who has a g35 and we can just use those test results for mine
now lets hope the gov doesn't read this thread and track my ip
Old Oct 20, 2010 | 02:56 PM
Lol... I know of a stock g35 sedan. Not sure if the door type or year make a difference. I'm stock anyway, besides a muffler so i'm good now
Old Oct 20, 2010 | 02:59 PM
eurodre's Avatar
its like every 5 years or so? i should be good too just gettin different cat back with different y pipe
Old Oct 20, 2010 | 03:13 PM
  #30
Na, it's 6 years from where the car was purchased, then every 2 years after that.
