G35 & G37, Coupes & Sedans
3 questions
Old Oct 27, 2010 | 08:48 PM
soysssauce's Avatar
3 questions
running into few questions abt my G after owning it for 1 week.
1. tire pressure light is on, how many lbs am I suppose put in there? any different between front and back?
2. i saw a sticker on my gas door says fill with premium gas only. does it means fill with the top graded gas? i think the code is 92?
3. My G come with factory wing. how can I take it off? If i take it off, will it leave few holes on the trunk?
thank all.
Old Oct 27, 2010 | 09:12 PM
dumbg35x's Avatar
1. it depend on the tires you have. if regular tires.. stock rims and wheel.. its about 32-37 psi
2. the car run better with premium gas... in the long run.. but its always up to you.
3. not sure.. but one idea is to have someone local with the same color car.. to change with it so it won't cost much both ways.
Old Oct 27, 2010 | 09:43 PM
msommers's Avatar
1. PSI rating is on the door frame. Ie: open the door and look where it latches. Should have the VIN and a couple info stickers.
2. Premium means 91 octane or greater.
3. There is double-sided tape and I believe 2 screws holding it on.
Old Oct 27, 2010 | 10:55 PM
soysssauce's Avatar
great idea abt changing the trunk...thanx!
Old Oct 27, 2010 | 11:01 PM
Ep Drifter's Avatar
i actually bought my OEM wing cause i love the way it sets off the back end of the car
Old Oct 27, 2010 | 11:06 PM
soysssauce's Avatar
I like the look too but im planning to get an kstyle rear, the wing just seems doesnt looks right with this kit IMO
Old Oct 27, 2010 | 11:23 PM
Wannabe6MT's Avatar
-MN G Crew-
Tire pressures are generally 35-40psi and yep, premium fuel generally means the highest octane rating that you can get....
Old Oct 27, 2010 | 11:43 PM
the_sedan's Avatar
the light comes on at 28psi. i set tires to 38psi.
just use premium 93.
and swap with someone with a wingless trunk. lol
Old Oct 28, 2010 | 12:21 AM
HavokGT's Avatar
imo... look up the straft speed coupe trunk... ya its 900 bucks painted and shipped.. but it makes me pinch tint...
Old Oct 28, 2010 | 02:09 AM
N@eem's Avatar
btw pics dont do it justice
Old Oct 28, 2010 | 04:40 PM
soysssauce's Avatar
I have the same wing as u.....I just think without wings look lil better..do u got pic of 75degree view? a pic that can see both side and rear..
Old Oct 28, 2010 | 04:52 PM
N@eem's Avatar
ill take one after work
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
