*** List Your Mods Up To Date ***
Motordyne MREV2
Motordyne 5/16 spacer
Stillen Intake
Kinetix High Flow Cats
Megan Racing y-back
Tein Springs
Tint
Trunk Lip Spoiler
6k/3k HID's
Grille (Black)
Clear Corners
Interior Led's
Debadge
Momo Winter wheels with Winterforce Tires
350z Wheels (Bent
Stillen Intake
Megan Racing y-back
Tein Springs
Tint
Trunk Lip Spoiler
6k/3k HID's
Grille (Black)
Clear Corners
Interior Led's
Debadge
350z Wheels (Bent
Its not alot but its getting there
Engine/Drivetrain Modifications:
Takeda Short Ram Intake
Z1 Motorsports Plenum Spacer
Brakes Modifications:
Stoptech Street Performance pads
R1 Concepts Slotted and Drilled Rotors
Interior/Exterior Modifications:
Headlight restoration
clear corners
20% window
debadged
To be installed when I find the time:
Polished some engine parts
paint my grille
put on eibach springs
clear corners
20% window
debadged
paint my grille
Everything you see on my signature plus I just received my SPL upper adjustable A-Arms which I will install next Tuesday along with getting an alignment. My Cusco arms didn't offer enough adjustment to keep my PS2s from wearing out the inside 1/4s. They'd be perfect for a OE height G that didn't require much for tire wear issues. So I spent $700 which includes my alignment to save $800 worth of front tires...makes sense to me.
Gary
Gary
MD Spacer
Ztube
JWT Pop Charger
Grounding kit
Fumoto oil plug
Tint redone 5%
debadged
side molding removal
eyelids
headlights/door lights/interior lights
aux cable install
rims painted
calipers painted
megan test pipes
Ztube
JWT Pop Charger
Grounding kit
Fumoto oil plug
Tint redone 5%
debadged
eyelids
aux cable install
rims painted
calipers painted
megan test pipes
Exterior:
Tinted tail lights
15% Tint on windows
Debadged
Clear Corners
Painted Grill
Paint Headlights
Matte black Diffuser painted
Matte black Roof
Lip Kit
All bulbs changed to white LED’s – V-LED’s
Upgraded stock HID’s to 6k– V-LED’s
Converted stock fog light to 6k HID’s – V-LED’s
Suspension:
Eibach Sport line
Front and rear camber kit - SPC
Project kicks Neo Chrome lug nuts
One off Custom; Staggered 20's - Savini SV25's
Custom Staggered 20's - Savini SV25's
BBK
Stereo:
iPod Integration
Fully Insulated Trunk
Monster Wiring
2x MXT 5601 Amps (600 RMS each) – Custom Painted
2x Alpine Type R Subs (500 RMS each)
Custom Box and Amp Rack
Various accent LEd's
Engine Bay:
NRG Carbon Fiber Hood Damper
NRG Carbon Fiber Strut Bar
Carbon Fiber Engine Cover
Carbon Fiber Wrap Battery Cover
Nismo Radiator Cap
Nismo Oil Cap
Intake - takada
Motordyne 5/16" Spacer
Custom Exhaust
Build thread in SIG
Tinted tail lights
15% Tint on windows
Debadged
Clear Corners
Painted Grill
Paint Headlights
Matte black Roof
Lip Kit
Suspension:
Eibach Sport line
BBK
Stereo:
iPod Integration
Monster Wiring
Engine Bay:
Nismo Radiator Cap
Nismo Oil Cap
Intake - takada
Custom Exhaust
Build thread in SIG
Engine/Drivetrain
*Stillen Intake
*Z-Tube
*Designed Chaos Throttle Body Spacer (with heat sinks and phenolic bore insert)
*DEO machined upper and lower collector
*Motordyne 1/2in Iso-Thermal Plenum spacer and coolant control valve
*Stillen Engine Damper
*JWT S2 cams
*Crawford Jet Hot Coated headers
*Crawford HFC
*Stillen Cat-back exhaust
*3.692 (3.7) FD Ring & Pinion Gears
*Quaife ATB differential
*UpRev's Osiris ECU tuned by Shawn Church (previoulsy had TechnoSquare which is also very good).
*NRG Oil Catch can (thanks Randy) w/braided steel hoses & AN fittings
*Venair coolant hoses (black)
*caskyline Ground Wire Kit (mostly hidden) - previoulsy sxexcx it (which is very good too) - before that, Stillen (poop)
Suspension
*Stillen anti-sway bars
*Tanabe Coil-overs (not common, took a chance & like 'em)
*SPL V-2 A-Arms
*SPC/Eibach rear camber adjusters and toe bolt
*Powergrid Endlinks
Wheels/Tires/Breaks
*Volk CE28N - 19X8.5, +35 offset with 20mm H&R adapters/spacers
*Toyo T1R - 245/40/19
*Akebono BBK (custom painted)
*Racing Brake 2-Piece rotors - Front & Rear w/RB ET500 pads & braided stainless lines
Interior/Exterior
*re-paint entire car - Porsche Meteor Grey Metallic
*Kurookie front bumper (Kuruma Z replica) modified
*smoke anodized painted emblem delete grille
*Smoke anodized headlights with clear signal lens
*shaved trunk with molded spoiler/lip
*smoked tails with blinker painted body color and molded into quarter panel
*KPTechnologies custom turn signal module - blinker delete (only one of its kind - brake lights blink for turn signal - FX style)
*body color door handles, window trim & mirror bezels
*shaved doors (omit door guards)
*molded Rookie side skirts (modified)
*flared fenders
*molded rear valance & bumper - no seems/lines/gap anywhere on the rear of the car
*molded custom hood cowl
*FX cup insert : )~ thanks Viet (actually is one of my favorite functional mods!)
*body color radiator core support
*shaved and body color battery cover (including JDM right hand drive cover)
*full wire tuck and other stealthy tweaks
*wheel-well blended & smoothed/shaved
*Entire engine compartment painted body color
*black chrome powder coated plenum & plenum spacer
*black-chrome painted throttle body
*custom shaped CF 1/2 cover (Z type) painted black chrome and air brushed graphics (thank you Paul Black, Outerlimits tattoo)
*black chrome painted intake, including intake snorkle (with airbrush graphics), air box (shaved Stillen heat shield and OEM box), Z-Tube, all fluid reservoirs
*true black chromed fluid reservoirs caps, Tomei oil cap, radiator cap, oil catch can, hose ends and TBS
*black chrome painted hood dampers/struts
>Interior<
*black suede headliner & A,B,C pillars
*all plastic pieces shoulder high & up painted gunmetal
*padded leather door panel and center console armrests
Way too much, look for build thread in near future featuring numerous one of a kind mods.
Built Long Block High Compression Engine
Freshly Built 5AT Trans w/ALTO Red Eagle Kit
Vortech Supercharger w/Custom mounting plate and Drive Pulleys
Fully detailed chassis with powder coated front/rear suspension
Filled/smooth engine bay
Custom stainless steel overlays and piping
All aluminum reservoir tanks
All Braided steel lines with AN fittings in Engine Bay
All Polished Accessories
Custom Gage Pods
Etc., Etc., ..........
Custom Gage Pods
ENGINE & EXTERIOR
MREV2
Replica HKS exhaust
Osiris standard tune
Kinetix HFCs
Z1 Motorsports Intake tube
K&N drop-in
carbon fiber hood dampers
Nismo Poly front bumper
1-off custom rear diffuser by Ionic
Generic Emblemless front grill
De-badged
Custom painted oem Rays 19's
Muteki extended lugs in titanium
5% tint
V2 projector black housing headlights
led's everywhere
Tein H-Tech 350z springs
GTSpec front upper strut bar
JDM battery cover
JDM white corner signals
AIT carbon fiber 350z engine cover
Hubcentric 15 & 20mm wheel spacers
INSIDE
Impul polished shift ****
Pioneer avic930 dvd/nav w/ rear camera
Hifonics 300w amp
custom fiberglass sub enclosure, JL 10w1
led's everywhere
NRG Black Infiniti floormats
MREV2
Replica HKS exhaust
Kinetix HFCs
K&N drop-in
De-badged
5% tint
led's everywhere
JDM battery cover
INSIDE
Hifonics 300w amp
led's everywhere
Also do you like the sounds and HP gains? I was looking to get some but im not sure I have heard good things about ART pipes and Berkely HFC but not much about Kinetix ones.
Engine
MREV2
MD 5/16" Spacer
Z-tube
Tanabe Medalion Exhaust
Tananbe Medalion y-pipe
Berk HFCs
Suspension
350Z S-techs
Tokico HP shocks/struts
rear spring mount mod
GT Spec strut bar
Exterior
Varrstoen 2.2.2 gloss black
Front headlight overlays
Rear GTR tail light overlays
Clear corners
UTR rear spoiler
Ionic rear diffuser
Debadged w/ black mt fuji
blacked out grill & emblem
Full Tint
Interior
Voodoo shift ****
MREV2
MD 5/16" Spacer
Z-tube
Berk HFCs
Suspension
350Z S-techs
GT Spec strut bar
Exterior
Clear corners
UTR rear spoiler
Ionic rear diffuser
Full Tint
Interior
Voodoo shift ****
My list for my '06 6MT Coupe
-Headlight Housings Painted Black
-Nissan Clear Corner Lights
-Smoked Taillights
-Tein H-Tech Springs
-Rear Springmount Mod
-Rogue Engineering Short Shifter
-Nismo Titanium Shift ****
-Z1 Motorsports SS Clutch Line
-DC Sports Headers (Heat wrapped and sealed)
-Berk Technology High Flow Cats
-Skunk2 Mega Power True Dual Exhaust System
-JWT Pop Charger (Will be replaced with Stillen Intake this week)
-Z1 Motorsports Z-Tube
-Stoptech Brake Pads F&R
-Greddy Oil and Radiator Caps
That's it for now. Next up is a Technosquare ECU
-Smoked Taillights
Current list:
Exterior:
- OEM 06 Projector Headlights (chrome housing) with 6000K HID's, LED City Lights, and TRS FX-R Projector Lenses
- JDM "Bump" Corner Lights w/ LED lights
- Ionic Gialla Grille
- Ionic C/F Nismo Rear Diffuser
- OEM Rear Splash Guards
- Strafe V2 Trunk
- Debadge except Mt. Fuji
- JDM Taillights w/ LED Backup Lights
- Project Kics Heptagonal Lug Nuts
- Hella Supertone Horns
- JDM RHS Battery Cover
Brakes & Suspension:
- KW Variant 1 Coilovers
- SPL Pro V3 Front Upper Camber Arms
- SPL Pro Rear Lower Camber Arms
- SPL Pro Eccentric Lockout Kit
- Custom Made Rear Toe Kit
- GT Spec Front Strut Brace
- Stoptech Brake Pads
Engine/Engine Bay/Transmission:
- DC Sports Headers, Heat Wrapped and Sealed
- Motordyne ART Pipes
- Skunk2 Mega Power Exhaust
- Motordyne MREV2 Lower Intake Manifold
- Motordyne 5/16" Manifold Spacer
- Stillen Z-Tube
- Stillen Hi Flow Intake Kit
- Stillen Engine Damper
- Greddy Oil & Radiator Caps
- Greddy Aluminum Air Diversion Panel
- Rogue Engineering Short Shifter
- Z1 Motorsports SS Clutch Line
- Replaced Clutch Master & Slave Cylinders
- RJM Performance Clutch Bracket
- UpRev Osiris Tuned
Interior:
- Tommy Kaira Hebi Bebi Shift ****
- Nifty Shifty Shift Boot
- Nismo 380RS Gas Pedal
- Valentine 1 w/ Mike's Mount & Invisicord
Soon to come, Stillen Exhaust to replace the Skunk2 and also Comp Clutch Lightweight Flywheel and Upgraded Clutch.
8.8:1 weiseco pistons, eagle rods, acl main bearings, acl thrust bearings, acl rod bearings, 1mm cometic head gaskets, revup oil pump, arp head studs, arp main studs, AAM oil pan spacer, Turbonetics single 60-1 turbo kit, custom 3" exhaust, BC Racing coilovers, hotchkis front ans rear sway bars, white line endlinks, gtspec front strut bar, gtspec rear strut bar, gtspec lower lateral bar, gtspec lower front and rear tie bar, stoptech front and rear steal braided brake lines, stoptech front and rear slotted rotors, hawk HP+ front and rear brake pads, B&M trans cooler w/9" fan, Enkei rpf1s 18x10.5 rims, arp extended wheel studs, seibon carbon fiber hood, vis carbon fiber trunk, vis carbon fiber rear deffuser, motordyne plenum spacer, prosport oil pressure gauge, prosport boost gauge, prosport water temp gauge, Aem uego wideband.
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
