G35 & G37, Coupes & Sedans
WD-40 on brakes
Old Dec 20, 2010 | 09:29 PM
Kindaofast08's Avatar
WD-40 on brakes
Is it harmful to the breaks if WD-40 comes in contact with the pads, calipers, or rotors?
Old Dec 20, 2010 | 09:32 PM
Frankieg35's Avatar
Na just make sure u clean them real good before u drive on them..
Just with soap and water. I drove like literally 5minutes to the car wash before i washed em
Old Dec 20, 2010 | 09:33 PM
Frankieg35's Avatar
Is use brake cleaner..
Old Dec 20, 2010 | 09:35 PM
What do you think it would do if I havent used brake cleaner
Old Dec 20, 2010 | 09:36 PM
Frankieg35's Avatar
Soap and water should be fine..
Swivel's Avatar
Moderator
And brake cleaner - just get some, you don't want to screw around here. Clean thoroughly!! I'm assuming it was accidental and you're not using WD40 on your brakes.
Old Dec 20, 2010 | 09:39 PM
i used it on my tsx in close proximity with the rotors. There was some surface rust that i scrubbed off of the rotor, not the face but the part that the lug bolts stick out on. WD-40 got on the rotors and pads though.
c_morse's Avatar
Can't agree more. You need to use brake cleaner to remove the lubrication that WD-40 provides.
Brakes are the one area of a car you really don't want to take any chance with.
Old Dec 20, 2010 | 09:41 PM
I hear ya! I did it about a week ago and cleaned it right after i was done with a pressure washer... fu@%
Old Dec 21, 2010 | 12:20 PM
4DGS's Avatar
I use break cleaner for everything... lol
Old Dec 21, 2010 | 12:35 PM
TannerG's Avatar
Originally Posted by SwivelHips
...I'm assuming it was accidental and you're not using WD40 on your brakes.
But they were squeaking....
Old Dec 21, 2010 | 07:29 PM
Rockst*r-G's Avatar
I have a friend that Uses WD-40 on his rotors and then Burns off a layer by slowly driving it at low speeds and holding down the breakes lightly, it removes any squeaks. It really dose work.
Old Dec 21, 2010 | 07:31 PM
Frankieg35's Avatar
Interesting..
Old Dec 21, 2010 | 07:40 PM
thescreensavers's Avatar
Mr.202?
WD-40 is a horrible lubricant, after you apply some pressure and some heat it will be gone.
But I would feel safer having it cleaned.
