The most gas Ive ever pumped into my G
Junk in fuel can be bad, but mostly what will happen is if your filter isn't catching the junk, your injectors will be clogged and have to be cleaned, unless it's REALLY bad. It shouldn't be REALLY bad because the fuel in the tank is constantly sloshing around which kind of stirs up the tank so whatever junk is in the tank is getting sucked in anyway, but filtered out.
However, I'd be more worried about burning out the fuel pump. In order for to it stay cool, there needs to be a constant supply of liquid. When you're running on fumes, you're making your pump work harder and run hotter. When you're in motion, what's left of your fuel is sloshing around and it's completely depriving the pump of any liquid. Keep doing that and your fuel pump is going to prematurely fail. That's a pretty costly repair bill.
i dont see how it matters because your fuel pump is always pulling from the same point.
Yeah, you get a lot of crud sucked in from the bottom. No thanks =D
Every other cars I've owned have the filter sitting on the firewall.
Back to the subject: How much gas have you pumped? Normally I don't let SLICK get below 1/2 full but on a trip I put 18.6 gallons in her tank, gauge was below 1/4....
Gary
Gary
http://www.fuelly.com/driver/ejoe19/g35
The most I've had to fill was only 64.31 litres or 16.99 gallons. The price of gas at the time was $1.446 per litre ($5.474/gallon) so that fill-up cost $93 CND. The very next day the price of gas in the GTA went down $0.07/litre.
The fuel level goes down when the cars parked on an uphill and the fuel level goes up when its parked on a downhill.
Our tank is ~20 gallons with ~16 gallons being a "full" tank. ~4 gallons are reserve so your car is fine.
