G35 & G37, Coupes & Sedans
after changing water pump and gasket due overheat help plz
Old Oct 26, 2011 | 05:04 PM
who4ever's Avatar
Exclamation after changing water pump and gasket due overheat help plz
I just get overheat 2 weeks back . After I take car to workshop they said that I have to change water pump, thermostat and head gasket (they check head pressure and they said its fine no need to replace)
3 days after I take car from workshop I experienced overhead again up to 50% as my car is GCC spec and normally gauge is on second line from down. But this time it was little crazy
the gauge was going up and down so fast like with seconds down and again up
I send the car to workshop again and after three days they said everything is fine and no problem is there
I take car and everything was normal till 3 day
Temp gauge again goes up till 50% . I switch of the car for 2hrs and start again and drive it gauge again go’s up but this time up to 75% I just pull over but I heard something like poooof (it was like noise if water flow or steam ) after that noise gauge come down within 1 second to normal level
I drive car again (I have video below from this moment) till car stop moving  and no more starting
watch below link please
<iframe width="640" height="360" src="http://www.youtube.com/embed/hHZTL-X-DQI?rel=0" frameborder="0" allowfullscreen></iframe>
I open de hood and saw there is housing pipe which go from engine side to body ( sorry I don’t know what is exactly name of that pipe ) it’s totally cut/broken from middle
I take car to same workshop when they open the engine. First they mechanic guy was totally impressed for broken pipe he said to me this pipe is so heavy duty and he never saw before like this
Anyway after 2 days they said to me that cylinder block has to be changed because of damage (ref to below pics )
Uploaded with ImageShack.us
I ask them way this happened and they saying coz your injector was not injecting properly and it was injecting direct to that point coz it was dirty or.. This damage its happened
But im not believing that I want to blame them coz I believe they did something wrong during changing my gasket and water pump
Can someone help me with that plzzzzzzzzzzzzzzzzzzzzz
Old Oct 26, 2011 | 06:05 PM
Sylvan lake V35's Avatar
Maybe make a few more threads about it you get better answers that way...
https://g35driver.com/forums/engine-...ml#post6185456
Old Oct 27, 2011 | 06:39 AM
Blue Dream's Avatar
I drove ttrank's car solo
Since you're a 2nd gen are you still under the 6 years 70K mile powertrain warranty? Your motor's blown and needs a rebuild or replacement, good luck.
KevinnnVo
Oct 14, 2024 04:33 PM
Smittie20
Aug 9, 2015 04:29 PM
ghost_g35
Aug 7, 2015 10:31 AM
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
