G35 & G37, Coupes & Sedans
what else should i do while installing plenum spacer?
Old Oct 27, 2011 | 12:02 AM
funnyscreenname's Avatar
got the MD 5/16" spacer on the way. going to do the install next week sometime during my off days. i'm gonna follow the DIY for the install and i'm really looking forward to it. i'm wondering tho, what else should i do while installing the spacer? i'd like to clean the plenum and maybe the throttle body as well. i'm going to make sure my intake is well sealed and all. i've thought of porting the lower plenum and maybe smoothing out the ports and runners. i've got a great bit for shaving the metal away and also some flapper wheels to polish everything to a smooth finish. anyone have any ideas on what else can be done while installing the spacer?
Old Oct 27, 2011 | 12:59 AM
Gdriver90's Avatar
spark plugs for SURE!
Old Oct 27, 2011 | 01:11 AM
bluedevils95's Avatar
What else did you have in mind while getting that install?
Old Oct 27, 2011 | 12:36 PM
LoSt180's Avatar
If you have the time and tools, go ahead and port the lower plenum while you have it apart. There's an awesome DIY on my350z on how to do it, just jump to the last 5 pages or so for what people are currently doing: http://my350z.com/forum/engine-drive...m-porting.html
Old Oct 27, 2011 | 01:18 PM
gary c's Avatar
Great idea....^....and it never hurts to have both upper and lower plenum super clean. Spark plugs, only if you have in excess of 60K miles on your VQ motor. Make sure you follow the instructions to the letter, correct torque specs and battery disconnected while doing the install....1 to 2 hour max. other wise your ECU will forget why it's there. I wouldn't mess with the TB at this point.... Later!
Gary
Old Oct 27, 2011 | 01:41 PM
redpearl99's Avatar
^so what happens if you disconnect the throttle body for a day or 2? Im going to take mine off to polish it so there's no way I can get it back on within 2 hrs. Just requires a normal TB relearn?
Old Oct 27, 2011 | 05:28 PM
what spark plugs should i go with if i change them? i've always been told it's best to use what came on the car originally and that some aftermarket plugs can do damage. also, where do you purchase them? if i can save a few bucks by ordering online i don't mind waiting for the shipping. otherwise i'll get a set from autozone.
btw, thank you for the port and polish link.
Old Oct 27, 2011 | 05:32 PM
Gdriver90's Avatar
depends on your budget, cant go wrong with oem replacement, if you got the cash do greddy l7.
Old Oct 27, 2011 | 06:48 PM
redpearl99's Avatar
get the OEM NGK laser platinum plugs
Old Oct 27, 2011 | 07:18 PM
lost, i just wanna say thanks again for that link. i think i wanna find a complete manifold to completely port and polish. if i do decide to find another manifold to work over should i look for a certain manifold?
Old Oct 28, 2011 | 07:09 PM
Think I'll go ahead and change the spark plugs as well. Just can't decide if I wanna go NGK platinum, double platinum, or try the iridium. Anyone tried the iridium yet?
Old Oct 29, 2011 | 05:15 AM
Blue Dream's Avatar
I drove ttrank's car solo
I have the iridium and honestly can't tell a difference in them from stock.
JMFeld02
Intake & Exhaust
Feb 25, 2016 07:50 PM
CoupeObsession
Aug 17, 2015 01:05 PM
Raven7
Aug 14, 2015 04:40 PM
deathsupport
Canada
Aug 2, 2015 10:13 AM
