G35 & G37, Coupes & Sedans
Problem with my g35 coupe 03 help asap pls
Old Jun 24, 2012 | 09:02 PM
Michaelh90's Avatar
I was going down to the south today when after 4 hours of drive i start hearing a knocking sound by engine.. I check online for help and find out theres little oil inside. Put 3 quarts of syntetic oil and boom no knocking sound is working great again. Now after a mile of drive the sound comes back i check theres oil leaking under the car and now my g doest start =[ help please asap what should i do?
Old Jun 24, 2012 | 10:29 PM
Eno's Avatar
Eno
I get that you're an 03 coupe but you haven't really told us anything. CLEARLY it's obvious what the problem is and clearly it's not a warranty item. You don't have any photos or given us any indication of where it's leaking from- so nobody can even help to ease your mind with it being an easy fix or something horrible and expensive. For all I know your drain plug wiggled free or fell out.
Get a tow to your nearest trusted shop (or dealership if you're constipated).
I mean really dude- your car is broken down. What would you do if it was a 86 accord?
Old Jun 24, 2012 | 11:32 PM
SUMATIC's Avatar
If theres no visible leak under the car check your coolant reservoir for oil in it. And do you remember if smoke was coming out the exhaust?
Old Jun 25, 2012 | 06:59 AM
Michaelh90's Avatar
Theres is a leak under my car by the middle if the car.. There was smoke coming out of the exhaust. Im gonna get it tow to my house any help? I have an 03 which means im out off warranty so im taking to a shop not to dealer.
Old Jun 25, 2012 | 07:29 AM
VQ35DE215's Avatar
anywhere is better than dealer, but yeah by the sounds of it, it could be pretty much anything since you're getting smoke too. spark plugs could be a problem in that.
Old Jun 25, 2012 | 07:38 AM
Th3R3dStar323's Avatar
take that bad boy to the shop.
leaky vavlve seals maybe?
Old Jun 25, 2012 | 07:53 AM
slim17265's Avatar
I am thinking bad seal at oil filter base against block
Old Jun 25, 2012 | 08:43 AM
Michaelh90's Avatar
Hopefully u guys are right.. I dont want to swap the engine =[ im 200 miles from home tow truck is charging me $900 bs. im getting a u haul truck for half that =[
Old Jun 25, 2012 | 08:47 AM
find someone with a truck and a trailer. does your insurance not give you one tow a year?
Old Jun 25, 2012 | 09:40 AM
Eno's Avatar
Eno
Holy ****- 900? Frick that's a worse laxative than a stealership.
Was the smoke coming from your exhaust or was it just oil leaking onto the exhaust as you were driving? Anyway hope it's something simple. Do you have any good shops around that would take care of you? Maybe someone in here could recommend. Go to your regional forum and shout out if you haven't already.
If you're not a member of the driver facebook group either that might be a good place to get some feedback on a shop that will do it right and NOT ream out your @ss.
Old Jun 25, 2012 | 10:05 AM
Michaelh90's Avatar
Theres lots of shops here that i dont trust in NYC, im gonna look that up.. Hopefully is something small like the spark plugs or a seals.. Otherwise im gonna be w/o my g for a while.. Got a uhaul truck going back now..=[ Thanksfor the help guys . Btw it has 75K if thats has anything to do.
Old Jun 25, 2012 | 10:20 AM
Eno's Avatar
Eno
North east g section (us)
Old Jun 25, 2012 | 01:50 PM
Michaelh90's Avatar
Anything else i should look for? I dont want to take the car to the shop if is something small. Hopefully is an oil leak on the valve cover that damage the spark plugs and i can do that my self change both plastiv.valve covers and spark plugs..
Old Jun 26, 2012 | 07:40 AM
Michaelh90's Avatar
So i spoke to the guy at the shop and he told me that if i ran the engine w/o oil 99% that i need an engine swap.. Hes going to take a look at it today and let me know. Ima start shopping.for an enginewould all vq35de fit my 03 g?
Old Jun 26, 2012 | 08:00 AM
Eno's Avatar
Eno
I'd be inclined to say yes-
