G35 & G37, Coupes & Sedans
g35 with sti bbs ??
Old Jul 14, 2012 | 04:19 AM
kristinavq's Avatar
g35 with sti bbs ??
has any1 put sti bbs on a g35 ?? i was thinking about trading my rays for them straight i know the bbs weigh around 16lbs . but dont if itll be a good idea
Old Jul 14, 2012 | 10:09 AM
pulsar1's Avatar
Unless they have changed it, the bolt pattern is still 5x100 so they wouldn't fit anyway.
Old Jul 14, 2012 | 12:02 PM
D&G35's Avatar
why the F would u do that??? i know they're bbs and all..but the Rays oem are forged too..so its not like u're getting an upgrade...if u really care about weight reduction, then why not invest in sum fully forged wheels that don't weigh much...and yes, the bolt pattern is different too like pulsar stated..
Old Jul 14, 2012 | 12:17 PM
Jaygotboost's Avatar
too much work for those wheels but if you really want then get a wheel adapter/spacer to push the wheels out and also have the correct bolt pattern for those wheels
Old Jul 14, 2012 | 12:29 PM
nogoodname's Avatar
05+ up they changed to 5x114.3 so it will fit. Don't know about the hub bore.
Old Jul 14, 2012 | 01:06 PM
Dubi2087's Avatar
Impreza WRX is 5-100
WRX STI is 5-114.3
Dubi2087's Avatar
Btw that would be a dumb idea.
Just my .02
Old Jul 14, 2012 | 03:01 PM
onthe3rdday's Avatar
hub bore is something large...maybe 70 or 73 so a hub ring would be necessary. In addition the offset is probably nasty, like 50ish or higher. SO in summary you can make it work with spacers and hub rings. Hope you are really feeling the look of those if you are going to need to go thru all that trouble to make it work
Old Jul 14, 2012 | 04:45 PM
Invalid_User's Avatar
Are we really discussing this?
Old Jul 14, 2012 | 05:24 PM
SDGenius's Avatar
http://forums.nasioc.com/forums/show....php?t=2239019
Old Jul 14, 2012 | 08:54 PM
kristinavq's Avatar
the main reason was considering this was the weight and the tire prices lol ive seen a couple g's around town with them it looks alright but the rays do look better i think ill just go with some rpf1's
Old Jul 14, 2012 | 10:19 PM
TougeMonsterG35's Avatar
looking for weight loss ????Oem 350z Ver. 1 track wheel 18lbs per wheel . Done! besides STI wheels are like +1000 so they will look like sunken battleship
Old Jul 14, 2012 | 10:31 PM
SDGenius's Avatar
if you would've clicked the link i posted you see that no STI BBS's are 16lbs and they all too thin in width and have obscenely high offsets. additionally the only BBS STI wheels that are 18" weigh 20lbs
Old Jul 14, 2012 | 10:45 PM
HenryLee's Avatar
I call BS. Photos or bust.
Most likely g35's w/ aftermarket Bbs wheels.
Old Jul 15, 2012 | 12:21 AM
239g35's Avatar
hellafail
