G35 & G37, Coupes & Sedans
engine won't work if not bleeded!
Old Aug 13, 2012 | 08:38 AM
carloxflow's Avatar
I recently did a flush to clean the cooling system and right after my water pump when bad! So o replaced the water pump, test drove the car and engine was over heating! Change thermo stat and same issue, stoped the car for 4 days and i did a research on this particular problem and the problem was not bleeding the engine!!! Smh......
Old Aug 13, 2012 | 08:43 AM
Texasscout's Avatar
A somewhat well known problem that's been discussed a few times here. That bleeder valve is hard to find it you don't know what your looking for.
Old Aug 14, 2012 | 10:49 AM
gary c's Avatar
Check it out, our SEARCH function does serve a purpose when used....Gary
Old Aug 14, 2012 | 12:10 PM
Mr. Brett's Avatar
^ Sometimes.
Old Aug 14, 2012 | 12:16 PM
seymore4's Avatar
m56
wow you got owned.
Old Aug 14, 2012 | 01:58 PM
Texasscout's Avatar
This place couldn't search it's way out of a paper bag... most times..
But this time it did work...
I used "bleeding engine cooling system"
https://g35driver.com/forums/search....rchid=13717942
Old Aug 14, 2012 | 03:14 PM
cmurphy84's Avatar
HAHAHA
I use Google to search this site.
Google: g35driver bleed engine cooling system
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
keresa777
Jul 27, 2015 09:04 AM
newg37
Jul 26, 2015 09:32 AM
Jadenkid22
Jul 14, 2015 12:33 AM
