G35 & G37, Coupes & Sedans
Creakign noise when turning?? help please.
Old Aug 13, 2012 | 12:09 PM
Cheech's Avatar
If i turn my wheel Left all the way i hear this noise.. can anyone identify or help me with this problem? thanks
http://www.youtube.com/watch?v=XZDJ7...ature=youtu.be
Old Aug 13, 2012 | 12:51 PM
tylerxfire's Avatar
i cannot watch ur video at work so it might not be the correct answer your looking for but normally a creeking sound while turning points to tie rod?
Old Aug 13, 2012 | 12:58 PM
nghiars's Avatar
could also be the wheel bearing. Does the noise go away when you turn back right? if so, check your dirver side bearing. you can do this by raising the car on that corner lifting the driver side wheel off the ground. if the rim wobbles, its the bearing. For our cars, you have to replace the whole hub assmebly to replace the bearing. Good luck.
Old Aug 14, 2012 | 06:41 PM
marcinr's Avatar
20 Year Member
That's no wheel bearing noise. It sounds like either a squeaky rubber bushing or some part of the suspension has lost its lubrication.
Old Aug 14, 2012 | 08:13 PM
SUMATIC's Avatar
Check your top hat.
magnetism80
Feb 1, 2019 10:00 AM
mattdg35
Sep 14, 2015 11:28 AM
NJ6MT
Sep 10, 2015 08:40 AM
