G35 & G37, Coupes & Sedans
2005 Infiniti G35 - Will not start - VDC OFF + SLIP Lights are on.
Old Feb 13, 2015 | 11:26 AM
cw757's Avatar
Hello! This is my 1st Help! Post here, I have a 2005 Infiniti G35 that will not start, typically when it it colder outside.
Heres what happens,
I put the key in ignition to start engine, turn key to 'ON' and VDC OFF, SLIP, and BRAKE, Oil, and Battery lights come on (Ive enclosed a picture). In addition to these lights, the radiator fan comes on as well. When turning the key to start, the car will try to turn over, but not successfuly start.
Heres what I have tried,
-Fill brake fluid
-Replace CamShaft Position Sensors(both bank 1 and bank 2)
-Check brake pads
-Cleaned/Secured ground connections
-Checked oil
The only thing Ive heard that I should try is replacing the coolant sensor? One of my mechanic friends suggested this because of the radiator fan on?
Lastly! This only happens when its cold outside/morning time? If i wait untill ~12:00 after the sun has rose, the car starts fine. No lights, no nothing.
Any help would be awesome!
Old Feb 13, 2015 | 01:57 PM
lonatic's Avatar
Heres what happens,
-Fill brake fluid
-Check brake pads
-Checked oil
You sure its the radiator fan thats on and not the ABS motor running?
Old Feb 13, 2015 | 03:29 PM
cw757's Avatar
Definitly the radiator fan, I assume trying to cool something?
Old Feb 13, 2015 | 04:42 PM
gmmills's Avatar
Crank sensor
Old Feb 15, 2015 | 04:40 AM
andrewx373's Avatar
Check the battery u had the same problem had to buy a ac Delco 2 weeks ago works great
Old Feb 18, 2015 | 10:49 AM
Mustang5L5's Avatar
Usually, if the engine is NOT running, a whole bunch of warning lights come on when you turn the key to ON. most disappear.
So, if you turn the key to ON and wait a min, what warning lights stay?
Old Feb 18, 2015 | 04:21 PM
helalo's Avatar
i ended up having to replace my ECU and battery when i had this. this might not be your problem and nissan might have ****ed me just because they can. i also had to replaced my camshaft sensors myself with aftermarket ones but that was not the problem.
start with the battery. see if its very old and need a new one. if it is, change it.
if the problem is still happening, scan the vehicle for any codes and go from there.
Old Feb 23, 2015 | 10:36 AM
nizoo_k's Avatar
have you checked if there are any codes stored in the ECM after the car starts?
Mry
Mar 3, 2023 01:03 AM
Blakelyg35
Jul 22, 2015 12:08 PM
Blakelyg35
Jul 21, 2015 12:49 PM
Jadenkid22
Jul 14, 2015 12:33 AM
