G35 & G37, Coupes & Sedans
Best mods?
Old Jun 24, 2015 | 05:44 PM
Tonka211's Avatar
Best mods?
So im buying a g35x in a couple weeks, and planning on modding it. Im not a huge car guy, and havent done any mods to a car before. I know I want to do an exhaust, and probably a cold air intake, or something similar. Im not necessarily looking to increase the hp because im not planning on racing it, but i want to make it look and sound good. Any suggestions on what to get or anything else to do to the car would be greatly appreciated, thanks!
Old Jun 24, 2015 | 05:49 PM
Osvaldo1064's Avatar
Lower it.
Old Jun 24, 2015 | 05:50 PM
SxExCx's Avatar
Intake
Plenum Spacer
Exhaust
Where are you from?
Old Jun 24, 2015 | 05:51 PM
Tonka211's Avatar
Im from Minnesota
Old Jun 24, 2015 | 06:21 PM
G2B35AGN's Avatar
Best mods?
There are threads on lowering an AWD you will want to read carefully. It's different from a coupe or RWD sedan. Choose your intake carefully. The stock setup is pretty optimal; some intake mods will actually cost you HP. A Z-tube will give you more growl to go with your exhaust note, but it's hard to beat the stock air box. Beware of heat soak.
Old Jun 24, 2015 | 07:22 PM
WhosUrBuddiee's Avatar
Tint, projector headlights, drop in filter, plenum spacer, mild drop, exhaust (in that order)
Old Jun 25, 2015 | 01:01 PM
Spartan268's Avatar
Originally Posted by WhosUrBuddiee
Tint, projector headlights, drop in filter+Z-tube, plenum spacer, mild drop, exhaust (in that order)
Fixed
For exhaust portion. If you want moar noize. You can go full catback + HFC/tests. Or just catback if you dont want anything over the top.
A tune will be needed though if you go the HFC/test + catback route doe
Old Jun 25, 2015 | 03:52 PM
Cat back makes almost no gains for bunch of money, it is really only worth getting for sound. Plus then will need to get tune. OP can save 1.5-2k by skipping exhaust and tune.
Old Jun 25, 2015 | 06:59 PM
gary c's Avatar
Would/could you drive a lowered car in Minnesota all year?
Best mods are always the ones that put a smile on your face every time you approach or sit behind the wheel of your car and turn the key...fact! When you have the car get back to us so we have the right information...Gary
Old Jun 27, 2015 | 10:51 PM
tha_ape's Avatar
G35 6MT Coupe
Not a fan of lowering unless you only plan on driving on smooth roads and no speed bumps.
Mrev2 + spacer are the best bang for the buck.
Old Jun 28, 2015 | 11:16 AM
gary c's Avatar
We can't give him accurate answers until we know what he's driving! Mrev2 is only worthwhile for those members driving '06/'07 coupes or sedans with MTs. He can't lower is car unless he wants to create a snow plow or park it in the winter!
Gary
Old Jun 28, 2015 | 11:38 AM
Lartytiejdke3's Avatar
Not a fan of lowering unless you only plan on driving on smooth roads and no speed bumps. Mrev2 + spacer are the best bang for the buck.
he said he's driving an X and I'm almost positive they didn't come 6mt aka revup
So no mrev2
Old Jun 28, 2015 | 02:34 PM
bluedevils95's Avatar
Lots of good ways to start on a project.
Old Jun 28, 2015 | 07:35 PM
Mr. Brooks's Avatar
Intake, exhaust, tint, high flo cats, mild drop, 20's all around (staggered setup), plenum spacer, a tune, stereo upgrade. All this should get you on your way.
Old Jul 2, 2015 | 06:26 AM
jrandys's Avatar
Getting a new set of wheels can bring a big improvement in the aesthetic look of your car.
