G35 & G37, Coupes & Sedans
What is wrong with my cluthc?!
Old Dec 11, 2015 | 05:51 PM
jdubin94's Avatar
Okay, so about 1.5 years ago, I got an Exedy Stage 1 Organic Clutch and lightweight flywheel installed. I am experiencing clutch chatter. But at this point, I am quite confused what clutch chatter really is. Some people refer to it as the rattling noise that the clutch/gearbox makes when the clutch is not depressed, which I certainly experience, but isn't a problem for me. But people also refer to it as the harsh vibrating and shaking that the clutch produces when launching, and I definitely experience that, and I absolutely hate it, and it's what this post is all about. So my first question is, is clutch chatter the noise or the violent shaking?
Now, as for the noise, I believe that has been going on since the moment everything was installed. As for the shudder, I am not positive but I don't think this has been happening consistently for the past 1.5 years now. If it has been, I would have made this post a long time ago. Are both of these things normal, because the research I've done suggests that the noise and the shaking are, with installation of a lightweight flywheel. Like I said though I don't mind the noise, it's the shudder that bothers me. I'd like to touch on that more. So yeah, many have said that "clutch chatter" is normal, but I don't know what exactly they are referring to. On the contrary, people have said that an Exedy stage 1 ORGANIC clutch should not produce "chatter". And on top of that, people said that "chatter" should go away after the clutch breaks in. It's been about 15k miles since the install so I don't think that's the case.. What's weird is that the severity of the shuddering isn't consistent. A few weeks ago, the shudder was AWFUL. I'm talking the whole car would shake violently. Then it randomly seemed to go away completely after I got my car washed, which is weird but I doubt there is any connection , and now, it's back but not as bad.. Can someone please enlighten me with information please? What's going on? Was the install done improperly?
Old Dec 11, 2015 | 07:54 PM
saywat?'s Avatar
maybe its time to replace the disk again. i had that with my old clutch. it was jus worn out
Old Dec 11, 2015 | 07:55 PM
jdubin94's Avatar
You think it's possible for the disk to have worn out that quickly? I don't ride the clutch or anything liek that..
Old Dec 11, 2015 | 07:59 PM
saywat?'s Avatar
idk u idk how u drive. but that is my experience with mine. for me it usually occured if i pressed the clutch twice going into first
jdubin94
Oct 25, 2015 01:29 PM
AL8782
Oct 3, 2015 10:26 AM
