G35 & G37, Coupes & Sedans
Underdrive pulley ??
Old Nov 11, 2016 | 09:49 AM
NeverTooFast's Avatar
I haven't seen it mentioned here on any diy but how exactly do you remove the a/c pulley? The alternator and crank bolt right off but that third pulley has like a cover plate. Assuming I'm even working on the right pulley.
Old Nov 14, 2016 | 01:09 AM
EPiK's Avatar
you don't remove the AC pulley. the set should just include the crank pulley, alternator, and the one you have on in the middle that looks like a water pump pulley, but is just an idler.
mine is the set from AMS, looks similar to yours. And they aren't underdrive, per se.. same size, just a percentage of the weight of the stock pieces.
make sure you pay attention to the running of the engine after removing the harmonic balancer (stock crank pulley) it can introduce vibration and cause internal issues.. not saying it will for sure..but can happen
Old Dec 27, 2024 | 09:43 PM
Teamoffdatrose's Avatar
2006 Infiniti G35 coupe rev up.
I have a 06 G35 coupe rev up 6-speed with lightened flywheel and a high output alternator and idler delete. Do you think it would be safe to put a underdrive crank pulley on? Has intake plenum spacer, bigger throttle body and spacer, intake, and full exhaust?
JKDman
193
Mar 13, 2006 11:12 PM
ChuckP
Feb 24, 2006 10:36 AM
triniG35
Aug 24, 2005 12:50 PM
