G35 & G37, Coupes & Sedans
Water Leak
Old Jun 24, 2017 | 06:12 PM
gloriam67's Avatar
Water Leak
i have water leak dripping on the fuse box on the driver side of my G35. I turned the air conditioner off and the water dripping stopped. Help
Old Jun 25, 2017 | 09:44 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Condesate weep hole is clogged, when the AC coil inside the vehicle is running it builds up ice which thaws. It's supposed to drain out of a weep hole and through a tube but it sounds like it's pooling inside the duct work of the vehicle and leaking out eventually. This might not be an easy fix but start at the glove box, take it off and the piece that holds the cabin air filter in. Hopefully you can access it from that side, might be a mouse nest or something built up in your duct that's plugging it.
Old Jun 26, 2017 | 07:19 AM
Blue Dream's Avatar
I drove ttrank's car solo
OP you need to address this ASAP, with as many electronics our cars have getting water where it shouldn't be can cause catastrophic failures. I think cleric's spot on with his assessment.
TheIronYuppy
Jan 25, 2017 12:26 PM
LZKS
Jan 22, 2017 02:11 PM
Lord Trazaza
Nov 14, 2016 12:42 PM
Leguan
Canada
Jul 8, 2003 11:51 PM
